AaronArf's 2012 DCSB Build
Discussion in '2nd Gen. Builds (2005-2015)' started by AaronArf, Apr 6, 2012.
  1. Jan 27, 2016 at 6:11 PM
    #1541
    AaronArf
    AaronArf [OP] Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    So you just cut off the ends on your factory harness and used butt connectors? Do you remember what Guage wires stock is
    Good to know that it does a decent job.
    And @ckeene9 lol
  2. Jan 27, 2016 at 6:27 PM
    #1542
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    I would guess that stock is around 4ga.
  3. Jan 27, 2016 at 6:41 PM
    #1543
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Yep, been working fine for me for last couple years. Got a chance to get rid of that goofy positive terminal yota supplies for the starter. I believe 4 gauge or maybe 2. I'll have to check my home made wiring diagram and see if I wrote it down lol
    AaronArf[QUOTED][OP] likes this.
  4. Jan 27, 2016 at 6:44 PM
    #1544
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I did the same with all of the OE cables, chopped and extended so I could route them better.
  5. Jan 31, 2016 at 5:29 PM
    #1545
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Reserved for dual battery build/battery relocation.
    The main goal of doing this mod was to get the Diehard 31M removed from the factory battery mount because the oversize battery was damaging my inner fenders, causing stress cracks. Also a nice feature is redundancy, I will be able to switch between battery one and two, dual and all power off. I will lose a bit of bed space but oh well!
    Parts used:
    Artec Group 34 side by side battery cage
    Optima Yellow top Group 34/78 batteries X2
    Blue Sea Battery Bank Switch (PN 9001E)
    Blue Sea PowerPost Stud terminals 5/16" stud (PN 2002) X 2
    Blue Sea HD Battery On/Off Switch for a winch isolator
    3/4" Black Starboard HDPE, misc. hardware
    Knukonceptz 1/0 OFC wire
    Knukonceptz 4/0 OFC wire (winch pwr wire)
    Knuckonceptz Battery terminals x4
    Parts piling up...
    Figuring out how to lay out the power panel in the stock battery location
    Marine Starboard HDPE Thanks to Tony for cutting this at work for me!!
    Used some bolts/washers as a stud.
    Test mount
    Press in threaded inserts to mount the switchs/terminal studs on the HDPE.
    Came out pretty nice!!
    Painted the Artec mount with Rustoleum bed liner. Should have test fit first, was banking I could use the pre-drilled holes...nope nothing easy. They don't line up with the ribs in the bed so I used the center ones and re-drilled 4 holes.
    Waiting on some terminal ends and a few other odds and ends so I can start running wire and mounting the battery bank switch behind the seat in the cab.
    Update 2/3/16:
    battery isolator switch and in-line fuse mounted on hdpe behind the pass rear seat
    Also chopped up the stock battery harness and crimped on new ring terminals for the stud mounts.
    Pirhett, SonnyBones, Nate87 and 10 others like this.
  6. Feb 4, 2016 at 10:58 AM
    #1546
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    That's a good amount of weight transferred. Does she handle any differently now?
  7. Feb 4, 2016 at 12:37 PM
    #1547
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Looking good on the battery project Aaron!
    AaronArf[OP] likes this.
  8. Feb 4, 2016 at 5:22 PM
    #1548
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Haven't even driven it yet!! Still a work in progress...if only this weather would give me one good day I'll have it wrapped up. Gotta route the wires from the bed to the front/into the cab.
    DaveEli likes this.
  9. Feb 7, 2016 at 8:09 PM
    #1549
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    b113882fe440cea1962dab673df65232_781ba24782f2916b90042bf6b38d21993597b6c5.jpg7844fb64944c100717f19fe09eba9107_5ac4fa0cf0bfe775573b8b003dd42a2d5bff6b14.jpg63afc05c17902d5198f0584b71bae12a_7b1a2a80440f6d86deb5a4f07e30b9093ffad358.jpg2354525baa846de79c729b1e2c276b40_bdb929da04252cfb559a557d660d44fc6dd7301a.jpg
    She's running! Trucks drivable again, still need to run the winch pwr cable but I'm not going to mess with that until a warm day. I'll update this with details later
    Pirhett, scottalot, NateMob and 6 others like this.
  10. Feb 7, 2016 at 9:31 PM
    #1550
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Clean work Aaron, truck looks excellent brother :thumbsup:
    AaronArf[OP] and Crom like this.
  11. Feb 8, 2016 at 3:36 PM
    #1551
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Do you notice any difference starting from that far away? looks clean man
  12. Feb 8, 2016 at 3:40 PM
    #1552
    ckeene9
    Chesterfield, VA
    See Build Thread
    Shouldn't with that gauge wire run.
  13. Feb 8, 2016 at 4:26 PM
    #1553
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No noticeable difference, even with going from a 1150CCA battery to the 750CCA Optima's. I'm at .02 voltage drop from the battery to the terminal studs under the hood with the 1/0 OFC wire.
    Ended up running the winch power today, 4/0 and there is zero voltage drop from the battery to under the hood.
    I most definitely can feel a huge difference on the road! Almost 100 lbs moved from my front driver corner trucks road manners are much more predictable.
  14. Feb 8, 2016 at 5:34 PM
    #1554
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Wow, that's awesome to hear. I was thinking about doing a single battery upgrade but I've been torn between a diehard 31 group or an odyssey. It sounds like the diehard puts out way more CCA, but the odyssey handles abuse better? Are either of them worth it for a single battery upgrade? I have an Autozone duralast gold right now haha
  15. Feb 8, 2016 at 5:40 PM
    #1555
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I love this but I'm thinking more under the bed for a battery box. Glad to see you moving the weight off the front.
  16. Feb 8, 2016 at 6:22 PM
    #1556
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Die hard platinums are rebranded Odyssey's...pretty sure sears discontinued the 31m.
    Whatever you do, get the battery relocated elsewhere.
    If I had the room under my bed that's where I'd stash them, prime opportunity for you since you chopped all your factory stuff out already!
  17. Feb 8, 2016 at 6:24 PM
    #1557
    2ndGenJonny
    Jon
    Gilbert, AZ
    Yes I did! I was thinking that area or opposite the fuel cell.
  18. Feb 8, 2016 at 6:30 PM
    #1558
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Exhaust might cramp your style on the pass side
  19. Feb 8, 2016 at 6:37 PM
    #1559
    2ndGenJonny
    Jon
    Gilbert, AZ
    Agreed, best bet is where the spare used to be.
    Il have the bed off in a few weeks. We will figure it out then and I'll have to hit you up when I pull the trigger.
  20. Feb 8, 2016 at 6:43 PM
    #1560
    ChandlerDOOM
    Chandler
    STL
    Truck
    37s yo
    Awesome, might have to follow your foot steps, I planned on running solar and moving my 31 behind the seat and using a smaller battery upfront to cut the weight down. But this option allows me to keep two decent size batteries.
    Pirhett likes this.
