abanger trans help
Discussion in '4 Cylinder' started by beckleyota, May 25, 2011.
  1. May 25, 2011 at 9:18 PM
    beckleyota
    beckleyota [OP] Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    i have a 07 axcess cab 4cyl 5spd. the truck has ben grindint goin into 2nd gear for a while now. ive took it to the dealer before for this and they drove it saying that to recreat the problem they have to really get on it. this is bs because it does it to me all the time i say the 2nd gear syncroniser is goin out and they just dont want to warranty it. the truck has almost 52000 and im the third owner if that matters any
  2. May 26, 2011 at 6:34 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Not saying your synchros aren't going out, but the 5 speed manual in the 2nd gens is kind of notchy. There are plenty of folks who have similar complaints when shifting from 1->2 and from 2->3. The URD short shifter helps smooth it out.
  3. May 26, 2011 at 5:12 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I would try the following 1st;
    1) Drain and fill the trans with new fluid
    2) Try Redline Trans fluid
    3) Replace the shifter w/ URD SS......I just happen to have an never installed extra one to sell if you're interested, PM me for specifics.
    Good luck,
    Motoretro
