About to order... parts list
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JP tacotime, Aug 13, 2018.
  1. Aug 13, 2018 at 12:10 AM
    JP tacotime
    JP tacotime [OP] Member
    2011 double cab trd
    Finally getting that lift I wanted. Just thought I'd double-check my parts list on here before I push the green button.
    I already picked up EL095r rear Springs from someone local on Craigslist. Brand new never installed for 250 bucks. So I'm piecing together the rest of the lift from Wheelers. 2011 DC shortbed TRD Tacoma 4x4. Here's what I've come up with...
    -886coils, kyb top plates, trim packer, nitrocharger front struts.
    -SPC upper control arms
    -rear nitrocharger shocks
    -Wheelers u-bolt flip kit
    -front & rear +2" brake lines
    -Bora 1" wheel spacers
    -carrier bearing drop
    Haven't decided yet if I'm going to run 285 70/17 or 255 80/17.
    I've done some research and I'm prepared to do the cab mount chop if I need to. From the research I've done on here looks like I should get about 3 in all around. Any input before I go ahead and order it would be appreciated. Thanks in advance!
    lynyrd3 likes this.
  2. Aug 13, 2018 at 5:35 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Bumpstops ?
    JP tacotime[OP] and DrFunker like this.
  3. Aug 13, 2018 at 5:46 AM
    lynyrd3
    Bill
    Welcome to TW :spending:
  4. Aug 13, 2018 at 5:49 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Nice setup you have there I have essentially the same setup I got 3 in out an about 2.75 up front but I’ve got armor up front. I went with 255/80/17 just prefer the tall skinny look either way it’ll look great. Also took my sway bar off for better flex.
    JP tacotime[OP] likes this.
  5. Aug 13, 2018 at 6:43 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  6. Aug 13, 2018 at 6:59 AM
    Tylerh147
    Tylerh147 Well-Known Member
    Tyler
    Chattanooga, Tennessee
    2007 DCSB TRD OR 4x4
    5100s, 885s, Icon AAL
    You might need an ECGS bushing afterwards
  7. Aug 13, 2018 at 7:10 AM
    JP tacotime
    2011 double cab trd
    See I knew there was a reason I posted this! Forgot about the bump stops. I've added them to the flip kit.
    I have not come across anything about the ECGS bushings. Definitely will look into that. Going to be doing hub bearing assemblies at the same time I do all this so if there's anything else in there I want to do it all the same time. Is this something required for the lift or more of a preventative maintenance thing?
    Can the CMC plates be purchased somewhere? I just assumed everybody was making their own
    lynyrd3 likes this.
  8. Aug 13, 2018 at 7:45 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Some people make their own but there are tons of options for the CMC plates: https://amzn.to/2P2IycV
  9. Aug 13, 2018 at 1:14 PM
    JP tacotime
    2011 double cab trd
    So I originally had the 886 coils on there. When talking to the guys at wheelers they said they would be way too stiff without additional front weight. They recommended the 887 coils with a 3/8 top spacer. Does that sound about right? I will eventually be getting the front bumper but probably the trail gear tubular Style which I don't think weighs very much.
  10. Aug 13, 2018 at 1:32 PM
    lynyrd3
    Bill
    I went Bilstein 6112s for around 2.5” .
  11. Aug 13, 2018 at 1:35 PM
    Tylerh147
    Tyler
    I would get a 1/4" top spacer, but for driver side only. That, paired with 887's, should get you around 3". If you go any higher, you run a higher risk of damaging cv boots.
  12. Aug 13, 2018 at 2:16 PM
    JP tacotime
    2011 double cab trd
    I included the trim packer with my order. So you wouldn't recommend any spacers then if I'm using the trim packer?
  13. Aug 13, 2018 at 7:48 PM
    Tylerh147
    Tyler
    I must’ve read over that. Use the trim packer for the driver side. You shouldn’t need any top plate spacers unless you decide you want more lift
  14. Aug 13, 2018 at 9:03 PM
    Pigpen
    Dan
    Northwest Montana
    No spacer needed with the trim packer. If your truck is a V6 4x4, the 887 springs are a good call. Skip the CMC and go with the 255s.
    While you're in there and need an alignment anyway, pull out the LCA hardware and grease or anti seize it so they don't seize up on you.
    Happy lifting!! :benchpress::militarypress::curls:
  15. Aug 13, 2018 at 9:04 PM
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    Have some 887's for sale with at the most 2k miles on them if you are interested.
  16. Aug 13, 2018 at 9:12 PM
    JP tacotime
    2011 double cab trd
    Thanks for the offer! I already placed my order with wheelers though. Why did you switch from the 887 s and what do you have on there now?
  17. Aug 13, 2018 at 10:07 PM
    Fleabag
    Uriah
    Vancouver, WA
    I have 886's now, it was fine while I did not have a bumper and a winch, but once I had that extra weight I had to add a spacer to achieve the lift I was looking for with out a spacer.
  18. Aug 14, 2018 at 8:35 AM
    AustinPizzini
    AustinPizzini Well-Known Member
    Austin
    Huntersville NC
    006 ACLB SR5 ON KINGS
    285/75/16 Micky Thompson Baja MTZ P3, king 2.5 Resi coilovers, spiderTrax, cbi hood brackets, caliraised led pods, caliraised led bar in lower valance, UWS tool box, blacked out emblems, 18% tint, lots of audio stuffs
    I recommend the sway bar in the trash can mod
  19. Aug 14, 2018 at 8:55 AM
    JP tacotime
    2011 double cab trd
    Yeah I plan on just removing it haha.
