About to purchase a 2016 TRD Sport, is all this normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caligula, Aug 5, 2021.
  1. Aug 5, 2021 at 8:01 PM
    Caligula
    Caligula [OP] Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I was just test driving a 2016 metallic gray TRD Sport DCLB. It has been somewhat difficult to find the combination of options I wanted for the right price with the way the market is right now, though I really do like this one.
    Coming from a 1st Gen Tacoma, the feel is very difference as to be expected. I've also test-driven a number of 2nd gen trucks, however I've only driven a third gen one other time before today. So I'm curious to if what I am sensing is normal for the truck or is it something to be concerned about.
    First, I noticed turning the steering wheel is very thick and not as easy or effortless to turn the wheel as much as a second gen. The tires, according to the TPMS, we're slightly over-inflated at 37 PSI. Which would only assist in steering, not make it slower.
    Second, there is a noticeable delay in the throttle response. Even on the freeway it is one or two seconds until the engine catches up with the throttle. Is this to be expected with drive-by-wire systems?
    Third, I read from a few people on here about the "rumble pad" feeling that you get when you come to a stop in the 2016. I think I felt this as when going from a stop, along with the throttle lag, there was a bit of feedback from the car.
    Fourth, not really a concern with the car, I wish the seat could be moved higher. I'm 6'2" and I'm not a fan of looking over a hood scoop. It seems like I should be sitting up an inch higher than the stock height of the seat. Either that or the steering wheel extended outward more.
  2. Aug 5, 2021 at 8:09 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe try test driving a few different 3rd Gen's.
  3. Aug 5, 2021 at 8:17 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
  4. Aug 5, 2021 at 10:38 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Just an observation, when the steering wheel is at 12 o’clock position, there seems to be a bit of a dead spot in turning left or right. As if I have to sometimes oversteer.
  5. Aug 6, 2021 at 4:24 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    The third gen has it's issues but it sounds like that particular one's not the truck for you. Your paranoia now is going to grow if you buy that one. Like previously said, try a different one.
    Abject4x4 and IrishRed like this.
  6. Aug 6, 2021 at 4:43 AM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Other than the steering effort, I would say all common complaints for the 3rd gen.
    There are many complaints about the engine/transmission on the third gen. The engine likes to rev and makes it's power in the upper RPMs paired with a transmission programmed for fuel economy that shifts into higher gears as fast as possible. It takes some time for the combo to figure out you want some power and to downshift. There are probably some programming TSBs that could approve this situation.
    The rumble pad feeling is also a common complaint. There are a few TSBs for driveline vibration. I've seen fixes ranging from rotors, rear brake drums, rear axles, shims, tire balance etc. https://www.tacomaworld.com/threads/oh-no-tsb-0171-16-driveline-vibration.463992/ I think this may be the newer TSB https://www.tacomaworld.com/threads/2020-tacoma-driveline-vibration.645448/page-5#post-24928740
    For the seat adjustment, a lot of people use seat spacers to change the position of the front seats. https://www.tacomaworld.com/threads/seat-jackers-spacers-risers-blow-out-sale.729542/
  7. Aug 6, 2021 at 8:56 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    The 2020 and 2021 has powered driver seat and has height adjustment.
  8. Aug 6, 2021 at 9:04 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That TSB is not applicable to the 2016s, but there are others that might help with that dead pedal. I would suspect that the one the OP is looking at is not updated.
  9. Aug 6, 2021 at 9:07 AM
    chstaco
    SC
    2020 Tacoma
    Good catch, I should have linked the ECU TSB post in your sig.
    tonered[QUOTED] likes this.
  10. Aug 6, 2021 at 9:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
    No worries. Even the noted VIN ranges in the actual TSBs can be wrong.
    :cheers:
    chstaco[QUOTED] likes this.
  11. Aug 6, 2021 at 9:20 AM
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    Been driving my 2016 for 5 years and never felt a rumble
    Beerpayzdabillz and shakerhood like this.
  12. Aug 6, 2021 at 10:20 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    use the ECT button, major difference.
  13. Aug 6, 2021 at 10:29 AM
    coma toy
    coma toy Off Road Taco
    Don't waste your money on a Sport. The Off Road rides better, on and off road. Do the test drives before you buy.
  14. Aug 6, 2021 at 10:32 AM
    A Florida Man
    A Florida Man Well-Known Member
    NW Florida Gulf Coast
    ‘13 Tacoma Limited Double Cab
    Look for a second Gen.
  15. Aug 6, 2021 at 10:41 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    If possible, test drive a bunch of them, take the one that feels best.
    davidstacoma, Junkhead and shakerhood like this.
  16. Aug 6, 2021 at 2:19 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    motorick, Shocked, Bleep100 and 5 others like this.
  17. Aug 6, 2021 at 2:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Go drive a new one. Then compare.
    davidstacoma and shakerhood like this.
  18. Aug 6, 2021 at 3:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
  19. Aug 6, 2021 at 3:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  20. Aug 6, 2021 at 4:33 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    nice
    Junkhead and chstaco like this.
