About U.C.A total chaos
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDOFFROAD14, Feb 18, 2019.
  1. Feb 18, 2019 at 10:41 AM
    TRDOFFROAD14
    TRDOFFROAD14 [OP] Well-Known Member
    Manny
    Lanai city hawaii
    2023 tacoma 4x4 offroad
    I have a 2014 tacoma with 3” of level lift and aftermarket rims and tires, 285 70 17, and i want to install a total chaos U.C.A,, will i need to realign it again or will it be the same,,
    After i got it lift, i realign ,,
  2. Feb 18, 2019 at 1:13 PM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    After installing a set of TOTAL CHAOS UCA'S, your vehicle will need an alignment. The geometry between our UCA and factory is different and it will change some of your numbers. Having the alignment checked will make sure everything is where it needs to be.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  3. Feb 18, 2019 at 4:56 PM
    TRDOFFROAD14
    Manny
    Lanai city hawaii
    Thankx for ur reply,,
    And also , with my 3” level lift 2” rear block,, what is the recommended shock to put on, using a after market 285/70R17 tire and rims? I was thinking about belstein 5100
    TacoZim likes this.
  4. Feb 19, 2019 at 9:51 AM
    TOTAL CHAOS
    Corona, CA
    Shock recommendation will come down to personal preference and application. We have many customers running King, Fox, Elka, Radflo, etc. Bilstein is another option that customers run on their rides
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Feb 19, 2019 at 10:03 AM
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    5100's would be fine for your application
