ABS and traction indicator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bubbarr, Mar 22, 2012.
  1. Mar 22, 2012 at 11:30 PM
    Bubbarr
    Bubbarr [OP] Monkey Sweat
    Duane
    SD
    TRD Off-Road 4X4
    DynoLock Auto tailgate lock, 16" Konig Counter steer Off roads, 265/75/16 Goodyear Wrangler Duratracs, 2.5 King front and rear with remote reservoir, Built Right UCA, Deaver 3 pack, SD Truck Shop Custom Sliders.
    Hey guys, over the last so days or so my ABS light and that traction control sliding truck icon have been turning on. Does anyone know what this means? Is this my indicator that it's time for new brakes or does this mean something bad? This is for a 2009 tacoma TRD offroad 4x4.
  2. Mar 23, 2012 at 2:52 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    take to shop have it checked out.
  3. Mar 23, 2012 at 1:23 PM
    Jreays
    Jreays Member
    Jeremy
    Ohio
    09 4x4 Sport Double
    Its weird... mine did that a couple of days ago. I parked, turned off the ignition and started it again. The lights went out. I have noticed that I am hearing a little more of a whine when I am taking off from a stop while everything is cold.
  4. Mar 23, 2012 at 1:29 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    Yeah. It's weird. My left front turn signal went out too. Doubt it's related but weird anyway.
  5. Mar 23, 2012 at 1:40 PM
    Jreays
    Jreays Member
    Jeremy
    Ohio
    09 4x4 Sport Double
    Do you use the ultragauge by chance? I just read someone elses post where they were using one and had the same problem. I use one and I am sure that is what cause my problem. The whine... I maybe just haven't noticed it before.
  6. Mar 23, 2012 at 7:56 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I am not using an ultra gauge.
  7. Mar 25, 2012 at 5:00 PM
    Birdy
    Birdy Member
    Canmore, Alberta
    2009 Tacoma
    I have the exact same issue. Started about a month ago. Initially the lights came on sometimes, but other times the lights would be off. Now they both are on all the time. I dont have ABS or Traction control when the lights are on, so the systems are definitely linked together and definitely not working when the lights are on. Before I go to the dealer and spend big $, Im wondering if anyone has found the solution... sensor, wires unhooked, etc??? Any help would be appreciated.
  8. Mar 26, 2012 at 2:26 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    My abs light was coming on sometimes but would go away when the ignition was cycled. Now it comes on everytime i turn on the truck and pulled code c1249: open in stop light switch circuit. My truck is a 2006 with 2010 tail lights.
  9. Apr 3, 2012 at 8:34 PM
    Birdy
    Birdy Member
    Canmore, Alberta
    2009 Tacoma
    Do you think the code you pulled is related to your ABS and traction systems or your 2010 tail lights??? Mine is definitely related to the ABS and traction systems...
  10. Apr 3, 2012 at 8:40 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    Might be a connector is loose somewhere just check your abs wire that's what happened to me the abs light would come on every time I hit a bump and loosening the connector
  11. Oct 5, 2012 at 3:31 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I have a 2009 TRD off road and have been having this issue for about 2 or so months. If my truck is in park and the lights are on you can not get the truck out of park. It appears to be thinking that this is no brake available. I have to step on my brake really hard sometimes to make the lights go out to get the truck into Drive. I have taken it in to a shop and they cant tell me whats up.
  12. Oct 5, 2012 at 3:31 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
  13. Oct 5, 2012 at 6:26 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Sounds like an issue with the stop light switch, possibly just adjustment if stepping hard on the pedal allows you to shift from park.
  14. Oct 6, 2012 at 1:46 PM
    Birdy
    Birdy Member
    Canmore, Alberta
    2009 Tacoma
    Mine turned out to be a damaged wire on one of the front wheel sensors. It appears a rock or stick probably crushed the wire. After replacing the sensor (sensor and wire coming out is one piece), all is fine. Beware the sensors are very expensive $$$$$.
