ABS brakes????
Discussion in '1st Gen. Tacomas (1995-2004)' started by ETaco23, May 10, 2010.
  1. May 10, 2010 at 6:04 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Do our trucks have ABS brakes? I was just told by my dad, That if you have ABS brake's you have to power bleed your brakes. I put new SS Brake lines on the front and just hand bled them. Everything is fine. But I was just wondering if I even have ABS? thanks!
    And please prove him wrong! :D
  2. May 10, 2010 at 6:09 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I know some 1st gens do but not sure which models. But look in your engine and follow your brake lines. If you do you will see the ABS motor. :D
  3. May 10, 2010 at 6:48 PM
    ETaco23
    Evan
    PNW
    I looked it up, but it just says some models came with it, and some you had to order it if you wanted it. But was it just the rear that had it?
  4. May 10, 2010 at 6:50 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    Yours is a TRD so im pritty sure it came with it. I think the base models it was an option and no you dont have to power bleed the brakes.
  5. May 10, 2010 at 6:52 PM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    Did the SS brake lines make the pedal feel any harder?
  6. May 10, 2010 at 7:06 PM
    ETaco23
    Evan
    PNW
    A little. Hard to tell since I did the Power Slot Rotors and Hawk pads at the same time. But I do notice a better stopping ability. :)
  7. May 10, 2010 at 7:13 PM
    mwild
    Vernon, NJ
    03 2500 Dodge Ram
    Nice im thinkin about puttind them on mine with the EBC pads and rotors.
  8. May 10, 2010 at 7:17 PM
    ETaco23
    Evan
    PNW
    Nice! that would be a good set-up too.:thumbsup:
  9. May 10, 2010 at 7:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you have ABS on your truck there will be an ABS controller mounted under the hood on the passenger side, on top of the wheel well, in that area between the Cruise Control unit and the windsheild wiper motor. You'll recognize it as it has about 8 metal brake lines going in and out of it. I'd be willing to be that you don't have ABS on your truck. Most 1st gen TRDs delivered to the PNW didn't have it.
    Not all TRDs have ABS, mine does not. The region the truck was originally delivered to had something to do with whether truck came with or not. Many of the 02s I've seen in the Pacific NW did not come with.
    SS brake line did improve my braking response/feel. Plus, less chance of snagging a line on an errant tree branch out on the trail. Definitely worth the expense.
    scocar likes this.
  10. May 10, 2010 at 7:45 PM
    ETaco23
    Evan
    PNW
    Im ganna go check.. be back!
  11. May 10, 2010 at 7:50 PM
    ETaco23
    Evan
    PNW
    Nope, I dont have ABS!!! Cool, now I feel better about doing my rear brake line..:)
    I havent done the rear one yet. Kinda been putting it off.
  12. Aug 7, 2019 at 3:10 PM
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    Power bleeding your brakes can help prevent damage to the master cylinder seals. Another way to check ABS is there should be an ABS dash panel light that illuminates when you turn your key to "on" if you have ABS.
  13. Aug 8, 2019 at 8:40 AM
    Hunt/Taco
    Hunt/Taco Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    My cousin's 2002 3.4 extended cab SR5 has no ABS brakes on it. Where as my 2003 2.7L Reg Cab, SR5 has ABS brakes!!
  14. Aug 8, 2019 at 9:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    cruisedon66 likes this.
  15. Aug 8, 2019 at 9:21 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    My 2000 SR5 does not have ABS.
  16. Aug 8, 2019 at 9:55 AM
    firstgentacotuesday
    firstgentacotuesday Well-Known Member
    CA
    ‘01 3.4 4x4
    My 01 SR5 has no ABS. Ive heard that the ABS on these trucks r horrible. Take that with a grain of salt but thats what I’ve heard.
    Hunt/Taco likes this.
  17. Aug 8, 2019 at 9:59 AM
    0xDEADBEEF
    0xDEADBEEF Trash Aficionado
    2000 reg cab 4x4 flatbed MT
    Am I the only one around here that looks at the dates on threads?
  18. Aug 8, 2019 at 10:56 AM
    Hunt/Taco
    Coleman
    Mine work pretty good!!
  19. Aug 8, 2019 at 11:45 AM
    Danjor2
    Danjor2 Well-Known Member
    Daniel
    Riverside
    01 Limited Double Cab Prerunner
    My limited 2001 double cab has them but I hate them. My Abs has tried to kill me multiple times. Hit a pot hole when braking, it goes off and it sucks at stopping the truck. I have rolled through 2 intersections from my abs kicking on and not working properly. I disconnected its electronics and I can stop on a dime now with my upgraded tundra brakes. Wish it was easy to delete all the abs crap in the engine compartment so it just sits there for now
  20. Aug 8, 2019 at 12:58 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    ive seen more and more extremely old thread revivals. I think people are getting a little too bored lol
    JasonLee likes this.
