ABS Delete 2001-2004 Tacoma
Discussion in 'Technical Chat' started by davidpick, Jun 8, 2015.
  1. Apr 24, 2018 at 12:44 PM
    davidpick
    davidpick [OP] NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    I purchased them local to me at Olympic 4x4 in Snohomish, WA. http://oly4x4.com/
  2. Jan 13, 2019 at 11:41 AM
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    If I disable my ABS with the fuse removal and leave the *faulty* equipment there is there any risk of the ABS equipment compromising my brakes? I’m considering doing this delete but it seems like a lot of work and I don’t need the engine bay space.
  3. Jan 13, 2019 at 9:06 PM
    pontoon
    Does this work on a 2000 Tacoma?
  4. Jan 15, 2019 at 8:59 PM
    davidpick
    David
    Leavenworth, WA
    I ran my truck like that for nearly two years with just the fuse pulled and all the plumbing and pump in place with no zero effects.
    pontoon[QUOTED] likes this.
  5. Jan 18, 2019 at 10:10 AM
    pontoon
    If I only buy the parts 47313, 47312 for the left and right front brake lines, can I remove the ABS pump and route from the T to left and right brakes? Does the ABS interact with the rear brakes at all?
  6. Jul 1, 2019 at 11:32 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Did you figure this out. I'm about to tear into mine and came to this point.
  7. Jul 6, 2019 at 8:58 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    I am just finishing up gutting mine out except I saved all the lines. Pm me if you have some questions. I haven't even bled them yet. But can help with a few things I am missing.
    Reh5108[QUOTED] likes this.
  8. Dec 3, 2019 at 7:05 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    did you ever get it finished? I’m getting ready to order parts, but seem to have conflicting part numbers. The OP listed 47312 and 47313 in his parts list and this is what the brake line diagram shows, but these appear to be incomplete part numbers. There is a post that shows a complete part numbers, but those don’t seem right when typed into Toyota parts deal’s website or any other. Can anyone help me with the part numbers?
  9. Dec 4, 2019 at 7:41 PM
    Adude
    Pnw
    04 Double cab
    Yeah been on the road for a while. I didn't order any new line, I got a hand bender and double flare tool and made my own. Took 2 days to run all new lines, fit everything install the disc brakes and line lock and delete abs.
  10. Nov 23, 2020 at 12:14 PM
    Billison_
    Billison_ Why does beer pair so well with wheeling?
    Billy
    ‘01 Ext Cab With Spension
    I changed the air freshener to a new one, one time.
    I called every custom hose company where I live and none can make these custom hoses.. said the thread pitch is really weird on the 3/8” fitting. I emailed the spot you mentioned above in Snohomoish, see if they still have em.
  11. Feb 8, 2021 at 12:59 AM
    __TT__
    __TT__ Well-Known Member
    06 sr5
    anyone done this mod on a 2nd gen? did the part list match up?
  12. Feb 8, 2021 at 1:24 PM
    bbeyota
    bbeyota Active Member
    Sacramento
    04 Tacoma 2.7
    Does anyone know if the abs pump is connected to the rear brakes? My abs is randomly activating (suspect broken abs sensor gear teeth) under light braking. Rear brakes are functioning properly and I don't want to remove/replace the proportioning valve. I am hoping to just install non-abs front brake lines (47313, 47312), remove the abs pump and rat nest of brake lines, and bleed the system. I probably will remove the abs fuse (small one) and dash light in the meantime but want to add a second battery in the pump location eventually.
  13. Feb 8, 2021 at 2:51 PM
    Billison_
    Billy
    Yeah they’re for sure connected to the rear. There are 2 lines running down the frame to the rear. I’d have to go in and check what you’ll keep and what you won’t. I have been planning on doing this just haven’t gotten to getting new custom lines. The ones listed in the write up are purely subject to pv placement. So might wanna either go long or get a tube bender and make the new ones yourself.
  14. Jul 14, 2021 at 12:02 PM
    Memphisfishman
    Memphisfishman New Member
    1999 Tacoma 4x4 SR5 V6 TRD
    Im considering this ABS delete...What about the ABS control harness, wires etc? Is the harness just left hanging, or can you undo it back to a certain point? I too could use the extra engine bay space for another battery
  15. Jul 14, 2021 at 12:06 PM
    #35
    Reh5108
    Idaho
    I left mine and wrapped it in electrical tape.
