ABS disable mod for 05+ Tacomas w/o VSC & locking diff write up *pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodstone, Feb 26, 2010.
  1. Dec 9, 2013 at 11:12 PM
    #181
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    And no your spot would be where I was thinking. I have to figure out how to pull that panel "in front" of my shifter. I think all that is in that panel is the aux and usb.
  2. Dec 12, 2013 at 9:21 AM
    #182
    tacoma4
    tacoma4 Well-Known Member
    Does the green wire in landphil's method have +12v? I would like to run it to a OTRATTW switch that will light up when I turn abs off. Would that be possible?
  3. Dec 12, 2013 at 8:43 PM
    #183
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yes, it has +12 ignition power at all times - regardless of the position of the ABS disable switch. You already have a built-in switched ground ("blue wire"), so the lighted switch should be easy as long as the illumination isn't polarity sensitive (ie, it has a bulb, not an LED).
  4. Jan 22, 2014 at 8:32 PM
    #184
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    just bumping this thread forward cause we got a foot of snow and i loooooove my abs disable switch!
  5. Jan 22, 2014 at 8:55 PM
    #185
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    I still have to do this I did the yellow wire mod a week before the snow
  6. Jan 22, 2014 at 9:00 PM
    #186
    DryCreek
    DryCreek Well-Known Member
    Utah
    08 DCLB TRD Sport
    Pioneer AVH-X2600BT Fog Anytime Trailer Plug Relocate (bullaculla) Ride Rite Air Bags OEM Roof Rack Rearview Camera Wet Okole Seat Covers Maxpedition Holster SOS Sliders Washable Cabin Filter Access Bed Cover K&N Drop In Filter Rearview Mirror Relocate (ImMrYo)
    Subed for next mod.......thanks
  7. Jan 28, 2014 at 6:12 PM
    #187
    stractman
    stractman Well-Known Member
    Colorado
    07 DCSB TRD sport, 4x4
    just posted this in the "so easy a caveman can do it" abs thread. i'll post it here as well to get some visibility on my particulars:
    many thanks to everyone who has posted these abs mods. with all the snow we're getting in colorado, it's a lifesaver. slamming on the brakes on snow is easier on my nerves now that i can get rid of that blasted abs.
    i have a 2007 trd sport, dcsb, 4x4. plain. no VSC, no diff lock, no traction control, nothing. you need a SPDT ON/ON switch with three prongs in back so you can ground it.
    use the switch in the landphil method which is a Cherry KG (P/N KGC2BNB1BBB) bought from here.
    wired it all up just like you described in this thread with a ground wire.
    here's the switch in place:
    here are the lights i get when i'm in 4x4 and i flip the switch:
    thanks again.
  8. Jan 28, 2014 at 6:22 PM
    #188
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    I just installed a standalone ecu and I don't have abs anymore lol
  9. May 11, 2014 at 7:57 PM
    #189
    Infmous89
    Infmous89 Infamous89
    Glenwood spring CO
    05 tacoma sr5 sport
    Hey bud quick question which fuse is the one to pull out I see 2abs fuses.
  10. May 11, 2014 at 8:50 PM
    #190
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I put my extra switches in the change holder pop out just infront of the fuses... look for a writeup soon on it.
  11. Jun 10, 2014 at 9:47 PM
    #191
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Worked like a charm for my 06 trd sport 4x4 I'm pumped I can't wait to put it to use thank you I love TW I have hated dealing with abs in the snow and off road
  12. Aug 24, 2014 at 1:08 PM
    #192
    TRD 13
    TRD 13 Active Member
    Spencer, WV
    2013 TRD double cab short box 6 speed
    6" rough country lift, 35" mud terrains
    ok, I just installed the switch via the landphil method. 2013 TRD sport. Same switch, same wiring schematic. Heres my question. With the switch in the down position the ABS light stays on. So does the VSC light (the little orange image of a car and the squiggly lines). With the switch up those lights stay on, and also get the following lights "TRAC off" and "VSC off". With this switch configuration should the ABS light not go out?
  13. Aug 24, 2014 at 2:45 PM
    #193
    landphil
    BC, Canada
    Tundra 5.7 mod
    The ABS light goes out when the switch flipped to the "normal" or "ABS ON" on my truck (2006) and to the best of my knowledge, for all others that have used the method I did the DIY on.
    Check that the fuse IG1#2 is not blown, and recheck that all connections are correct.
  14. Aug 24, 2014 at 3:59 PM
    #194
    TRD 13
    Spencer, WV
    Just rechecked all connections. No issue located. both the 30 and 50 amp ABS fuse under the hood are good as is the 10 amp in the IGN #2. Same symptoms persist. ABS light stays on even in "normal" mode, so does the VSC light. When I flip the switch the VSC OFF light comes on, along with TRAC OFF.
    Center wire from the switch (blue in your DIY writeup) connected to pin 4 (cut the light green wire and spliced "blue wire" into it). Top pole of switch connected to the other end of the green wire, going back into the harness. Bottom terminal grounded to truck. :confused:
  15. Aug 24, 2014 at 4:25 PM
    #195
    landphil
    BC, Canada
    Tundra 5.7 mod
    I'd be looking for a wiring diagram for your 2013 to see if anything has changed compared to the one shown a few pages back, maybe something is different with the '13s. It does appear that nd4spdbh did the mod successfully on his '13 though.
    What happens when you connect the (yellow and blue in my pics) wires back together? Did you test the on/on function of the switch with an ohm meter to make sure its not a faulty or mis-packaged switch? You should have continuity between the bottom and center terminals of the switch with the top of the rocker pressed, and continuity between the top and center terminals with the bottom of the rocker depressed.
  16. Aug 24, 2014 at 5:06 PM
    #196
    TRD 13
    Spencer, WV
    Im even more puzzled now. This evening I got curious and put the wiring back to the stock configuration. The ABS and VSC light still stayed on. It would make me think there would have to be a bad fuse. Checked both the 50 and 30 amp under the hood. Look fine. I swapped them out with other 30 and 50 amp fuses from the panel and nothing changed.
  17. Aug 24, 2014 at 5:11 PM
    #197
    TRD 13
    Spencer, WV
    This is a stupid question, but Im really grasping for a solution here. There is no such thing as "upside down" when installing the switch, right? Meaning that the top and bottom are interchangeable and not specific placements.
  18. Aug 24, 2014 at 5:28 PM
    #198
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
  19. Aug 24, 2014 at 5:40 PM
    #199
    TRD 13
    Spencer, WV
    Got it figured out! The ECU had a trouble code stored, I guess from when I was running with the ABS fuse pulled. Had to jump 2 pins on the OBD2 and clear the trouble code. Works like a charm now.
  20. Dec 31, 2014 at 9:21 AM
    #200
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Will this work for my truck? ?
