ABS disable mod for 05+ Tacomas w/o VSC & locking diff write up *pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodstone, Feb 26, 2010.
  1. Feb 16, 2017 at 7:59 AM
    #221
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yup, that will do it. If you look back at my photos, the bottom terminal of the switch is ground.(white).
    The connector side of the green wire (blue in my case) goes to the centre terminal.
    The other end of the green wire (yellow in my case) goes to the top terminal.
    Look at post 141 of this thread for the pics. The blue wire coming out of the connector body will green in your case, cut, and spliced to whatever wire you are using.
  2. Feb 16, 2017 at 8:47 AM
    #222
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I see now. So is the green wire mod is under the dash and yhe op is under the hood. Right?
    So my ? Is ,how many have done this with issuses?
  3. Feb 16, 2017 at 9:00 AM
    #223
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    So i see ehat he did wrong after reading your version through. He grounded the wrong side of the wire coming ftom the fuse. The light green wire or blue in pic.
    Like you said it comes from the fuse so that side should not go to ground.
    That said you should check your switch with a meter to insure that side of the green wire dosnt go to ground. If your not sure about what i said ask someone to help you with electronic / electrical background. I could draw a pic but it probably wont help.
    FishingInSand likes this.
  4. Feb 16, 2017 at 9:06 AM
    #224
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    So what I did was put the ground in the middle, that explains everything, I think you just gave me inspiration to try it again
  5. Feb 16, 2017 at 9:57 AM
    #225
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    exactly
    here is apic to help you
    This isn't my mod and I haven't done this yet just drew this up reading through the post. so if im wrong please correct me. I plan on doing this soon.
    landphil and FishingInSand like this.
  6. Feb 16, 2017 at 12:10 PM
    #226
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Awesome thanks man I'm still learning this stuff as I go, with it being used for work is a slight occupational hazard heh..
    And it's good to see what's in my mind layer out on "paper".
  7. Feb 16, 2017 at 1:09 PM
    #227
    landphil
    BC, Canada
    Tundra 5.7 mod
    Eggzackery! Nice diagram, I shoulda, coulda done that myself in my post originally, thanks for adding it.
  8. Feb 16, 2017 at 1:12 PM
    #228
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yup, mixing those up = shorting +12V straight to ground, which is why the fuse blew. Follow jqueener's diagram and you should have it.
  9. Feb 16, 2017 at 2:46 PM
    #229
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I find it helps to draw it out, as a simple drawing. a lot easier to follow when your working on it then to try and keep reading words on a cell phone under the dash.
  10. Feb 16, 2017 at 3:06 PM
    #230
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    This times 1000 lmao
  11. Feb 16, 2017 at 6:26 PM
    #231
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    So common to a terminal abs is on / common to b (ground) abs disabled
  12. Feb 16, 2017 at 9:52 PM
    #232
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Yes.
  13. Feb 16, 2017 at 9:56 PM
    #233
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    not all switches are the same so check the switch before install.
  14. Feb 18, 2017 at 1:11 PM
    #234
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I just finished this mod. Works perfectly.
    landphil likes this.
  15. Feb 20, 2017 at 9:39 AM
    #235
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    tested it out yesterday in snow,ice, and mud. i will say in the mud it was a huge improvement.
  16. Feb 21, 2017 at 9:53 PM
    #236
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Success!
  17. Feb 10, 2018 at 5:41 PM
    #237
    The Smith
    The Smith Well-Known Member
    Trinity Alps
    '17 4x4 V6 SR5
    Can anyone post a link (if one exists) to a similar mod for a 3rd gen (2017) SR5?
  18. Aug 6, 2018 at 4:13 PM
    #238
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
  19. Aug 6, 2018 at 5:13 PM
    #239
    landphil
    BC, Canada
    Tundra 5.7 mod
    A SPDT on-on switch must be used, but that could be a 5pin relay controlled by a SPST switch like you want to use. Pin 30 of the relay is then equivalent to the center terminal of my switch, pin 87a on relay is the top terminal of my switch, and pin 87 is the bottom terminal of my switch.
    Pins 85 and 86 are the control coil, one ground, one power, and switched by your SPST push button switch.
    TireFire likes this.
  20. Aug 6, 2018 at 5:18 PM
    #240
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yep but that's a lot of work just to not use a double throw switch
