ABS disable mod for 05+ Tacomas w/o VSC & locking diff write up *pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodstone, Feb 26, 2010.
  1. Aug 27, 2018 at 3:05 PM
    #261
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    ah...gotcha. ya, holding it down continuously doesn't sound like the best solution :rofl:
  2. Oct 15, 2018 at 5:43 AM
    #262
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    I keep popping the "IG1 No.2" fuse. My switch functions just fine when using alligator test leads to attach everything, but as soon as I connect my actual wires to the switch: the fuse goes. I've tried a different switch and checked over all my connections. Anyone else have this problem?
    (07 SR5, V6, 6MT, no nothing other than ABS)
  3. Oct 15, 2018 at 9:16 AM
    #263
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You must have a short
  4. Oct 15, 2018 at 9:48 AM
    #264
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    Did you make any progress on this?
    I desire the real estate taken up by the abs pump under the hood, and might be more keen to tackle this if someone else has broken trail.
    Haven't had my ABS functional since I bought the truck, and don't ever want it to be. Don't like how it(abs) only functions when you mash the pedal through the firewall.. -in slippery conditions-
  5. Oct 15, 2018 at 10:03 AM
    #265
    TireFire
    Olympic Peninsula
    Personally I think this is dumb and reckless but since you asked. You just need lengths of hard brake line and bypass the pump.
    Since you say your ABS hasn't been working nothing will change other than freeing up the space you want
  6. Oct 15, 2018 at 5:39 PM
    #266
    bdbrown
    Benjamin
    Canada
    '06 SWB DCSB MT
    :thumbsup:
  7. Apr 20, 2019 at 12:49 PM
    #267
    Lil red 02
    Lil red 02 Spendaholic
    Brent
    Sanford, Fl
    2005 Doublecab longbed
    so I just did this mod and apparently it seems to work when I crank the truck up the ABS light is on when the switch is engaged. The only problem I see with it which is no big deal I can definitely get over is I have to turn the truck back on and off once the switch is back off to make my ABS light turn off? Is that normal?
  8. Apr 20, 2019 at 12:57 PM
    #268
    TireFire
    Olympic Peninsula
    No, you didn’t do it right
  9. Apr 20, 2019 at 3:42 PM
    #269
    Lil red 02
    Brent
    Sanford, Fl
    Oh lord.....then im so lost i have tried 2 different ways and im over it. I have no clue what to try next. I figured when I crank it up with a switch off no light when I flip the switch to on ABS light comes on, the only problem seems to be that I cannot switch it off I have to turn the truck off flip the switch off when I re crank it it's back to normal?
  10. Apr 20, 2019 at 3:52 PM
    #270
    TireFire
    Olympic Peninsula
    Follow post #140 by @landphil in this thread. Follow to a tee and should work for your year/model truck
  11. Apr 20, 2019 at 3:53 PM
    #271
    Lil red 02
    Brent
    Sanford, Fl
    If done correctly you will not blow any fuses or melt any wires. I don't mind this part, but the ABS light will come on on the dash when you open the circuit with the switch (off), it's like a reminder that I flipped the switch. It will stay on til you turn your truck off but next time you start your truck with the switch closed the ABS light will be off.
    Here is the switch and location. I had to cut a notch in the threads so that I could flip the switch over since off is on(ABS disabled) and on is off(ABS enabled. Or you can think ofit this way off-ABS off and on-ABS on
    From the first post this is written and seems to match exactly what I did and my results :angrygirl:
  12. Apr 20, 2019 at 3:57 PM
    #272
    Lil red 02
    Brent
    Sanford, Fl
    I used a 2 pin rocker style safety switch so I couldn't accidentally hit or none of the kids in the woods could while I'm hunting so his thing has a 3-pin switch I didn't do it that way cuz I don't have a light on it it's one of those flip up safety style toggle switches no lights just like the OP had
  13. Apr 20, 2019 at 5:27 PM
    #273
    Lil red 02
    Brent
    Sanford, Fl
    And please don't take any of this as me being an asshole or any type of wrong way it literally is just me not knowing. That's why I posted the other parts that he had said I didn't know if I could have done it wrong
  14. Apr 23, 2019 at 11:39 PM
    #274
    ThePDXSkeptic
    ThePDXSkeptic New Member
    Gary
    1995 Forest Green Chevy Silverado Ex-Cab
    Running Boards, bed liner
    I have also heard of people using the front left wheel speed sensor to trip the abs light. Basically cut one of the wires (there are 2) and extend into cab and put a switch. This will trick the abs into thinking a wheel speed sensor is bad. Plus, now I'm not sure, I believe you don't have to cycle the ignition to re-enable the abs. Again, I'm not entirely sure about the cycling of the ignition. Just a thought!
    Sorry for all the weird edits! My first post so I was playing around with all the tools. Lol!:rofl::bananadance:
  15. Nov 18, 2021 at 8:22 AM
    #275
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    LOOKING FOR SOME HELP!!
    Is there a way to wire in a switch that quickly disconnects the VSC (traction control) in the Tacoma?
    I find that it takes too long to stop and press the VCS button for 3-5 secs to turn the traction control off. I've found myself in hairy situations multiple times where I need the traction control off immediately and there is no time to stop and do it the standard way. There has to be a way around it!!
    I have a 2010 TRD OR (w/ ATRAC, Rear Locker, etc.) manual trans.
    I have been searching and searching but no threads to be found. Maybe I'm not using the proper key words but any help or direction would be great!!
    (image for attention)
  16. Feb 3, 2022 at 8:49 AM
    #276
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Holding the button down for 5 seconds kills everything including ABS correct?
