ABS disable mod for 05+ Tacomas w/o VSC & locking diff write up *pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rodstone, Feb 26, 2010.
  1. Jul 3, 2012 at 12:14 AM
    #141
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I am having trouble understanding what you did there. What wires are being joined together and/or being run to the switch?
    Where did the yellow wire come from?
    It may be way too early for me to be looking at this......If you will, please baby me through this.
    Ok, looking back at a previous post, we are basically moving the wire from IA4 and IB1 plus a ground wire(that we install) to a switch, correct?
    IB1 is the blue wire that you are pointing to in your first picture, but will be green in my truck, correct?
    Can you show me where the IA4 slot is? Is this where the yellow wire comes in?
  2. Jul 3, 2012 at 3:47 AM
    #142
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    Thanks for putting up the detailed instructions and pictures. I've got a 2010 TRD Sport, is this the mod I should be doing? I can't keep track throughout this thread about which is for what kind. I think since I have no rear locker this is it... thanks!
  3. Jul 3, 2012 at 5:37 AM
    #143
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The Yellow wire connects to the Green wire and sends the ABS signal through the switch to the Blue wire to turn on the ABS. The white wire bring the ground to the switch to turn off the ABS.
  4. Jul 3, 2012 at 7:16 AM
    #144
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Landphil, you should create your own thread as your concept is different from the OP's. Congrats on your working solution. From your description it is a superior method to Rodstone's.
  5. Jul 3, 2012 at 1:47 PM
    #145
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The yellow wire and the blue wires are both wires I added. You can use whatever color you want, but I 'll keep calling them by color to try to keep things simple.
    The simple way is to cut the light green wire an inch or two back from IB1. Connect your "blue" wire to the short light green wire still in IB1. Connect your "yellow" wire to the loose light green wire, then follow the rest of the instructions with the ground wire and connect your switch as shown.
    I complicated things a bit, as I connected my wiring without cutting the light green wire, but the end result is exactly the same. Basically, in the "normal" position, the switch, yellow, and blue wires connect the circuit just like the light green wire always did. When you switch to "ABS disable" it opens the light green / yellow wire coming from the fuse, and grounds the blue / light green wire into IB1.
  6. Jul 3, 2012 at 10:53 PM
    #146
    Country101
    NW Arkansas
    Ok, I'm pretty sure I get it now. Basically, you pulled the green wire and connected it to the yellow wire you added. The yellow wire goes to the switch along with an added ground wire and then your blue wire goes from the switch back to where the green wire was pulled from.
    I'll be doing this once I get a switch. I havent decided if I want to put it on the dash in a factory spot, or get a cheap toggle switch and mount it in the space below the AC controls where it will be out of the way. This will more than likely be left in the disabled position, since I absolutely hate ABS on my truck. But I like being able to turn it back on, in case I sell it or somebody else drives it that cant drive themselves.....
  7. Jul 4, 2012 at 6:06 PM
    #147
    landphil
    BC, Canada
    Tundra 5.7 mod
    You got it!:thumbsup:
  8. Sep 3, 2012 at 6:57 PM
    #148
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Just did this on my sr5 and now I can have abs on and off on the Marty mcfly :). I cut the smaller blue wire with yellow tracer, spliced into a switch and done.
  9. Sep 6, 2012 at 12:09 PM
    #149
    oldtommyboy
    oldtommyboy Well-Known Member
    tom
    pa.
    tacome tx pro
    Does this work with the 4x4's with locker?
  10. Sep 6, 2012 at 5:28 PM
    #150
    landphil
    BC, Canada
    Tundra 5.7 mod
    It should be fine as far as the ABS goes since it sends the same signal to the ABS that the switch in the locker does. I just don't know how the ECU will like the "fake" signal that the locker is engaged. There is a separate thread on here for tacos with lockers, I think Crom started it. I would search for that and check out his method, and check out the wiring diagrams before attempting it with the method I posted above.
    By the way, mine has been working flawlessly with one exception. The ABS light has stayed on on two separate occasions until the key is cycled, but both times was when I disabled the ABS ( for no good reason) over 60 KPH. I think its logic is smart enough to know the locker should not still be engaged at that speed. At 50 KPH and slower, it consistantly works fine on the fly, which is fine with me.
  11. Sep 6, 2012 at 5:31 PM
    #151
    landphil
    BC, Canada
    Tundra 5.7 mod
    Should be A-OK for a sport. Your 2010 has VSC, no? If so, my understanding is that will be disabled along with the ABS.
  12. Sep 6, 2012 at 9:35 PM
    #152
    tacomafide
    tacomafide Cheese it in there!
    Sean
    Alberta
    '10 DCLB TRD Sport+Leather Pkg.
    de-badged, de-stickered, no jewlery, level kit (removed after second front dif), tint, skid plate (now dented), front tow hook off of Land Cruzer, reciever d hook (cleavis), yellow wire mod, abs kill sw. mod, window visors, stubby antena, anytime reverse lights mod, anytime reverse camera mod, blizzacks on stealies, bed lights mod, weathertec mats allround,
    Worked fine on my 2010 trd sport and yeah it kills everything which sucks when using in conjunction with yellow wire mod for 4 low. It's still cool though!!
    Pick the right one though./ your right it's a very confusing thread.
  13. Sep 6, 2012 at 9:37 PM
    #153
    tacomafide
    Sean
    Alberta
    Post #68 is the one I followed
  14. Sep 6, 2012 at 9:45 PM
    #154
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So with that method , you can't turn off the truck , and when you restart it , the ABS stays off ? It doesn't reset till you throw the switch correct ?
  15. Sep 7, 2012 at 5:20 AM
    #155
    tacomafide
    Sean
    Alberta
    Hmm not sure if I understand your question??? However if I turn my ABS sw. OFFI'm sure I could cycle ignition as often as I pleased and ABS would remain OFF. And yes I would not get ABS ON until the sw was in ON position regardless of engine running or not.
  16. Sep 7, 2012 at 7:38 AM
    #156
    OZ-T
    Peter North
    British Columbia
    Answers my question , thanks
    Does it disable the AUTO LSD ?
  17. Sep 7, 2012 at 4:01 PM
    #157
    tacomafide
    Sean
    Alberta
    Yup you can do fishies on gravel without the beeping and braking and I think it defeats the LSD as well. Kinda sucks. In a perfect world I could have ABS OFF and still have LSD ON.
  18. Sep 8, 2012 at 10:44 PM
    #158
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Mechanical LSD in the SR5 :D
    FishingInSand likes this.
  19. Sep 13, 2012 at 11:31 AM
    #159
    Crom
    Nick
    San Diego, CA
    Millions
    OZ, If you follow LandPhil's instructions it should work just fine for your truck. The presence of VSC should not matter at all.
  20. Sep 13, 2012 at 12:33 PM
    #160
    OZ-T
    Peter North
    British Columbia
    Thanks you sir
