ABS Disabling Mod, and ABS light / Fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Natemx, Oct 7, 2011.
  1. Oct 7, 2011 at 9:16 PM
    Natemx
    Natemx [OP] Active Member
    SoCal
    '09 5-lug
    Readylift for now. TC UCA's soon.
    I was pulling ABS fuses like I have done before with no issues. I had pulled the 30amp (ABS No.2) and the 50amp (ABS No.1) fuse with no issues. The ABS light goes on, Traction light goes on, and I go for a spin in the dirt. This time I thought I'd go one step further and see what ETCS stands for. It stands for Electronic Throttle Control System ( I suppose.) Now the ABS, Traction, and E-Brake lights stay on even with all fuses back in. I had a P2118 code which said "Throttle.........."
    1. Had error and lights on.
    2. Cleared codes, lights went off.
    3. Pulled 50amp ABS fuse No.1 to see which fuse gives the code.
    4. Now have Throttle code and cannot clear it.
    Will be having my mechanic look more deeply into OBD2 codes. Will also be looking into individual wheel sensors...
    Glad I opened up this can of worms on Friday night...
  2. Oct 7, 2011 at 11:22 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    pull battery for a few minutes, ten if you have time to kill, during this time make sure all fuses are plugged in.
  3. Oct 8, 2011 at 8:26 AM
    DaleD
    DaleD Member
    Take a guess.
    Colorado Springs
    Next time don't go 1 step further?
  4. Oct 8, 2011 at 9:51 AM
    Natemx
    SoCal
    '09 5-lug
    Good idea Dale D.
    Already pulled the battery for a few seconds while I cycled the key, I'll pull it for longer.
  5. Nov 17, 2011 at 10:26 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Im over the ABS on this truck in the winter here in Jackson, Wy. Seems to go off way to easily, and i drive SLOW on slick roads....Has almost caused me to slide through intersections multiple times every winter, way to sensitive on solid ice at intersections, and I cant stand it going off anymore!!!:eek:
    Anyone got a pic of what fuses to pull? Can any harm be done to the system by pulling the fuse? Great write-up on the disable mod Crom did, I just want to pull the fuse and be done with it though...
  6. Nov 17, 2011 at 10:38 AM
    wyotaco06
    Offroad 4x4 06
    Is there a fuse to just pull without having to do the mod, not really interested in installing a kill switch. If this is the only way to go looks like a radio shack visit is in order. Don't care it the idiot light is lit all winter either, just want the ABS disabled till May.
  7. Nov 17, 2011 at 11:04 AM
    Nonfatwater7
    Nonfatwater7 Well-Known Member
    Missoula, MT
    06 DC LB 4x4 Indigo
    Map Light mod, 265/70/17 BFG AT's, 5100's front set at .85, Eibach coils, Hi-lift bed rail mount, CB radio, Sway bar removed, 886 reverse light mod, LED tail lights and blinkers, Wickedflows exhaust, $4 aux/ipod input mod
    What about disabling it for tacos without a locker or vsc?
  8. Nov 17, 2011 at 12:25 PM
    Nonfatwater7
    Missoula, MT
    06 DC LB 4x4 Indigo
    I keep finding threads but none actually say this can be done on one without a locker or vsc...
  9. Nov 17, 2011 at 12:50 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  10. Dec 13, 2011 at 4:53 PM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    I know VERY little about electronics so forgive me if this sounds stupid. Dose the connector just plug onto the splice that is attached to the blue and yellow wire? I've never used one of thease splices before.
    thanks...
  11. Dec 13, 2011 at 10:29 PM
    kinkrider101
    santa barbara
    wheels and tires
    Cut the blue wire in half....the extend BOTH ends of the wire to the switch...that's it...super easy. Just use a quqick splice.
  12. Dec 13, 2011 at 10:32 PM
    kinkrider101
    santa barbara
    wheels and tires
  13. Dec 13, 2011 at 10:33 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    When you disconnect the battery you can tap both battery cables in the truck together, obviously while the battery is completely disconnected this will clear any memory the truck has stored and might take care of your problem.
  14. Dec 14, 2011 at 6:41 PM
    SPENCAF
    Shiloh, IL
    2012 TX PRO 4X4
  15. Dec 14, 2011 at 9:45 PM
    kinkrider101
    santa barbara
    wheels and tires
    that will work but don't forget that you are running 2 wires...one from both ends of the cut wire (blue/yellow) so the t tap isn't that ideal for it, but it will work. You would be better of just crimping the wires with with connectors.
