ABS Kill Switch mod for 05+ Offroad EASY WAY! (PICS)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Aug 7, 2011.
  1. Nov 21, 2015 at 4:35 PM
    #401
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I re did my switch today with an OTRATTW switch and used a relay so it will light up when the switch is on.
    Dash lights on:
    Switch on:
    DrFunker, Crom[OP] and DoorDing like this.
  2. Nov 21, 2015 at 4:39 PM
    #402
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    this is pretty neat!
  3. Nov 21, 2015 at 5:29 PM
    #403
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Yeah I like it. I wasn't sure if I could compete a ground with a relay but it worked perfect and lights up the switch.
  4. Nov 25, 2015 at 10:33 PM
    #404
    ninja89
    ninja89 HUH?
    Thanks OP!!! Just did this mod and it works great!! I was skeptical at first weather I could still use my rear locker on 4 LO. But it works I was also scared of frying my ABS module for this mod. But looking into it, it was ok to do the mod and safe as well (so far at least... Fingers crossed) But I'm on my way up to Tahoe for next couple of weeks. I'm Going to share a full review on his mod soon. Thanks again op!
  5. Nov 26, 2015 at 7:59 AM
    #405
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You're welcome. I use mine all the time when off road and around snow and ice. Works very well. :)
  6. Dec 4, 2015 at 7:02 PM
    #406
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Remove the AC control panel above, it is really easy - just pry on the bottom corners with screw driver to release latches on bottom then pull some more to get latches on the top. Came out pretty easy. Then you can reach with long fingers down from there and push out the blanks.
    ninja89 likes this.
  7. Dec 7, 2015 at 1:26 PM
    #407
    Jaab
    Jaab Well-Known Member
    Captain Wiggles
    SW Ontario
    2005 Double cab short box 4x4 TRD Taco....
    OME 887, Dakars ARB bull Bar, M8000 winch,ABS mod, Locker mod, fog lights anytime mod, COMFY BMW sport seats, tweaked Airbag emulator,
    Thanks Crom! A 10 minute, single beer job. awesome.
    DrFunker and Crom[OP] like this.
  8. Dec 9, 2015 at 9:29 PM
    #408
    DVexile
    Ken
    Completed this mod and used the Air On Board switch but without lighting (since the switch lighting arrangement won't work for a pull down to ground as this mod requires, though someone posted a relay circuit to make it work if you insist on lighting). Gave it a test and it works great! Took my time doing it, a bit of threading wires and what not because of the switch location in the center under the A/C controls (I have no blanks on the left).
    One again thanks to OP for a great write up and discovering an easy and very effective mod!
    Crom[OP] likes this.
  9. Dec 16, 2015 at 6:35 PM
    #409
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    Sorry everyone, my search skills are failing me. Apologies in advance if this has been covered before in this thread.
    Does anyone know what the minimum current rating should be for the switch? I assume this is a logic level circuit but have no idea WRT actual current the switch might see.
  10. Dec 16, 2015 at 7:25 PM
    #410
    Crom
    Nick
    San Diego, CA
    Millions
    See this quoted post below.
  11. Dec 16, 2015 at 8:52 PM
    #411
    Lostsheep
    NorCal
    2015 6spd 4x4 OR
    You're the man, thank you sir!
    Crom[QUOTED][OP] likes this.
  12. Jan 10, 2016 at 4:12 AM
    #412
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Great mod, been looking for this since ABS was born. Thanks CROM!
    I didn't use a wire tap connector, I've had trouble with them in the past. Each different color has a range of wire they fit, so they don't really fit any specific wire size exactly. The v-notch can damage the strands of the wire and you can't tell unless you open it and look, which defeats the purpose. So I just soldered the tap and protected it with a short piece of heat shrink. No possibility of a loose connection from off-roading bumps and bounces. Just my experience with them, if you like 'em, use 'em. Even if the tap goes bad, no harm done, other than repairing the wire at the tap. More - http://tech.bareasschoppers.com/resources/the-problem-with-wire-tap-connectors/
    My '06 TRD off road has 3 accessory blanks and I wanted to use one. I found a USA made aftermarket spst push switch that would snap into one of the blank spots. This also allows return to stock without much work at all.. just pop it out, unplug it, snap in the blank. $28 on Ebay, a little pricey but I wanted the look. It even lights up if you want. I didn't. If you do, dash light voltage goes to blue/green (light) wires ONLY, not the red/black (switch) wires, your ABS ECU won't like it.
    Mine - http://www.ebay.com/itm/251847942329?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Ebay store - http://stores.ebay.com/on-board-air-usa
    They have different looks to pick from. Measure your blank so you get the right one. Otherwise any spst switch will work. Have fun threshold braking like it should be!
    Later on, I changed the dash switch to one with "ABS" stamped on it, to keep nosey technicians from fiddling with it. Air Onboard has them if you're interested. Next post has a link.
  13. Jan 10, 2016 at 7:09 AM
    #413
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I ordered a switch directly from aironboard.com that will fit one of the center switch blanks in my '13. Went with green/green to somewhat match factory.
    http://www.aironboard.com/online/pu...toyota-oem-replacement-abs-off-led-green.html
    Not that there is any state inspection in Ohio, but I bet most inspectors in other states wouldn't even notice it. I'd just tell them that Baja's came that way :D Like 06Tacooo, I could always just pop it out and put the blank back in if I even want to return to factory.
    Anyway, check out aironboard.com. They have tons of cool switches and other stuff to fit factory mounting points.
    Jaab likes this.
  14. Jan 10, 2016 at 7:24 AM
    #414
    DrFunker
    DrFunker Well-Known Member
    Is it illegal to disable the ABS? I like the switch you posted but wouldn't use it if the inspector would see that and fail the truck.
  15. Jan 10, 2016 at 8:50 AM
    #415
    Crom
    Nick
    San Diego, CA
    Millions
    No.
    There is no federal requirement. I can't speak to all the individual state laws. My state doesn't do inspections.
    If my state did, I'd refuse to talk, or answer any questions from the inspector or any state, or government actors. :D
    At inspection time if truck is good, its good, so this mod should be a non issue, but that's my best guess.
  16. Jan 10, 2016 at 10:38 AM
    #416
    PaulK
    Paul
    Pittsburgh, PA
    I grew up in PA, where one of the strictest and most nonsensical inspection systems exists, and most of my buddies are still in Pittsburgh. My friends and I were, and still are hot rodders, so we know about getting modified stuff through inspections. If it isn't obvious or clearly unsafe it won't be caught during the safety inspection. A button in a stock location using the same font and colors won't get a second look. You'd have much more trouble with off-road lights, non-stock bumpers, lifts, and bigger tires, but I doubt anyone on this forum would suggest that these should be avoided.
  17. Jan 10, 2016 at 10:45 AM
    #417
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    I need to do this! Thanks @Crom for all your great write ups
  18. Jan 11, 2016 at 3:32 AM
    #418
    06Tacooo
    06Tacooo Earth Czar
    Mark
    It would be easy enough to return to stock.. pop out the switch, unplug it, snap in the blank.. done.
    PaulK likes this.
  19. Jan 11, 2016 at 12:02 PM
    #419
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    For all that snow y'all get *cough cough* It does help if you leave the parking lots though.
    Crom[OP] and Acerwin[QUOTED] like this.
  20. Jan 13, 2016 at 4:13 PM
    #420
    Papa Smurf
    Papa Smurf Don't get eliminated!
    Brett
    Central Oregon
    SOLD - '11 SWB DCSB TRD OR 6-Speed
    Taco has been sold. I no longer check this account :(
    So I just wired up the same switch, along with a few other OTRATTW switches for auxiliary lights, and realized that I will need a relay for the ABS killswitch to work properly. I'm somewhat electrically illiterate with relays being used outside of standard lighting applications. Could you provide an explanation or wiring diagram on how you wired up the relay? I have an idea of how it should [might] be wired, but figured I'd ask you since you're the only person I've found that wired up an OTRATTW switch with success.
    EDIT: I got the relay figured out and the killswitch works great, but the killswitch will only work with my headlights/parking lights off. Has anyone else had this problem when wiring the switch up with several other switches that control light bars, etc.?
