ABS Kill Switch mod for 05+ Offroad EASY WAY! (PICS)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Aug 7, 2011.
  1. Jul 4, 2016 at 4:27 AM
    #461
    HoosierTaco06
    HoosierTaco06 Well-Known Member
    Jeff
    Northwest Indiana
    2006 Tacoma TRD Off-Road
    Locker anytime, ABS killswitch
    Ha, that I was I kept saying last year, and then remembered once it started snowing out.:anonymous:
    DrFunker[QUOTED] likes this.
  2. Jul 4, 2016 at 4:28 AM
    #462
    DrFunker
    DrFunker Well-Known Member
    Yeah, same.
    :fistbump:
  3. Jul 20, 2016 at 7:34 AM
    #463
    DrFunker
    Crom[OP] and GHOST SHIP like this.
  4. Jul 20, 2016 at 7:45 AM
    #464
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    I would guess that this also allows you to turn abs back on without turning the truck off /on like other abs hacks need you to do.
    One more mod I'll need to get done.
    Crom[OP] likes this.
  5. Jul 20, 2016 at 7:47 AM
    #465
    DrFunker
    Flick of the switch is all it takes. :D
    Crom[OP], Stig[QUOTED] and GHOST SHIP like this.
  6. Jul 20, 2016 at 9:09 AM
    #466
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Welcome
  7. Jul 20, 2016 at 12:40 PM
    #467
    caribe makaira
    Caribbean, Puerto Rico
    No, he's asking for TAIL light tap, as in dash illumination.
    The switches above, are fogs and rear differential lock, they have the wires he seeks. GREEN (+) and GREEN with WHITE STRIPE(-)
  8. Jul 24, 2016 at 5:32 PM
    #468
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Finally done!
    I did this three weeks ago, but somehow, it did not work as planned.
    Had some time today to troubleshoot:
    Started with the ground to see if if connection was good. Check.
    Next, tested the switch to see if was functioning correctly. Check.
    Finally checked the T-Tap connection to the blue wire with yellow tracer. Fail.
    Closer examination showed that the metal slotted splice of the T-tap did not "bite" into the blue/yellow wire. I THINK it was because the wire was 12 years old and not soft/flexible, but more tough and hardened. I got rid of the T-tap, stripped the wire ends and performed an old school splice.
    Fixed. Works nicely.
    Thanks Nick!
    06Tacooo and Crom[OP] like this.
  9. Jul 24, 2016 at 8:06 PM
    #469
    Crom
    Nick
    San Diego, CA
    Millions
    Welcome! Good trouble shooting. :)
  10. Jul 24, 2016 at 8:13 PM
    #470
    Subway4X4
    Lloyd
    NY/NJ
    Yup. I'm turning into quite the automotive electrician. LOL!
    Crom[QUOTED][OP] likes this.
  11. Aug 2, 2016 at 9:15 AM
    #471
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Crom Switch installed. I got a push-button switch from aironboard.com and put it into one of the two center switch blanks.
    http://www.aironboard.com/online/pu...toyota-oem-replacement-abs-off-led-green.html
    I just wired it to ground the locker wire as in the original post - no relay to make the switch lights work. It's painted similar to the other non-lighted factory switches, and since you get multiple dash lights when it's on I didn't see the need for the switch to light up too.
    I also added dual USB power ports while everything was apart. Came out good and works like a charm. Thanks Crom!
    ajpagosa, DrFunker, Crom[OP] and 2 others like this.
  12. Aug 4, 2016 at 1:31 AM
    #472
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Thanks @PaulK for the link to the switch. This mod should be fun next time Im in the mud pit or when im in the sand.
  13. Nov 9, 2016 at 8:00 PM
    #473
    pattoyota
    pattoyota Member
    2015 tacoma supercharged
    supercharged TRD,oversize piston, bore head,titanium crankshaft, urd pulley, afe cold air intake. urd headers and s pipe,TRD exhaust,winch, bush bar with winch, icon stage 4 suspension,33 toyo tires, bed tire rack,4x4 locker anytime, bed rack with lights, air brush hood and tailgate, etc.......
    cool mod!
    5 min and it was all done, thanks! didn't tap into the wire using a tap, I just remove the connector in the plug and secure my wire to the connector and plug it back in the plug with the wire attach to it, works like a charmed!
  14. Nov 14, 2016 at 3:44 PM
    #474
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    One of the best mods I've done.
    scottalot and Crom[OP] like this.
  15. Dec 18, 2016 at 2:55 PM
    #475
    dmccurdy7
    dmccurdy7 Lurker
    Doug
    Caldwell, ID
    2010 6MT ACLB TRD Off Road
    Did you buy the dual USB switch from the same site? Can't find it. Also when wiring the USB, where do you tap into?
  16. Dec 18, 2016 at 7:07 PM
    #476
    PaulK
    Paul
    Pittsburgh, PA
    I got the USB outlets from Amazon: Cllena Toyota 2.1/2.1A Dual USB Charger Power Socket Blue Light with Fuse 2.3ft Wiring (4.2A-2)
    Use an add-a-circuit with a 5 amp fuse tapped into a switched circuit under dash: ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS
  17. Dec 19, 2016 at 3:05 PM
    #477
    dmccurdy7
    dmccurdy7 Lurker
    Doug
    Caldwell, ID
    Thanks, plan on doing this next weekend!
    PaulK[QUOTED] likes this.
  18. Dec 19, 2016 at 7:51 PM
    #478
    VolkswagenTaco
    VolkswagenTaco Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    Subbed. I off-road my taco a lot. I get this skipping with the brakes in soft sand and gravel. I'm assuming it's the dumb abs. My 99 taco didn't have abs. Thanks for the info!
  19. Dec 20, 2016 at 6:25 AM
    #479
    PaulK
    Paul
    Pittsburgh, PA
    I've had my kill switch in for awhile, but the weekend was the first real time that I had to use it. We had light snow over freezing rain, and even the flat Ohio roads became a challenge. Turning off the ABS really reduced my stopping distances. I leave everything alone when moving and just push the button if approaching a stop that looks iffy.
  20. Dec 20, 2016 at 7:12 AM
    #480
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    I have a 13' SR5 with 6 speed, I should follow the non offroad workaround with green wire correct?
