ABS Kill Switch mod for 05+ Offroad EASY WAY! (PICS)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Aug 7, 2011.
  1. Dec 13, 2011 at 4:45 PM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There is one
    http://www.tacomaworld.com/forum/technical-chat/180861-abs-kill-switch-non-locker-vsc-trucks-lets-discuss-feasibility.html#post3820978
  2. Dec 13, 2011 at 6:06 PM
    #42
    BRYLONATOR
    BRYLONATOR Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
    Thank you sir.....does the link look ok to you? I will try and see.
  3. Jan 14, 2012 at 3:56 PM
    #43
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Just finished doing the ABS Kill Switch Mod on my 2011 Tacoma offroad.Havent driven it yet to test. When flipping switch I get three lights on the instrument panel.Tomorrow I will give it the stress test.
  4. Jan 15, 2012 at 8:29 AM
    #44
    boomer6
    TN
    Tacoma TRD Offroad
    Took it out for a test run today, With ABS turned off . :) :) As Crom said it works GREAT!!You can lock them up if you want to,unlike when ABS is on.Stops alot quicker.Cant wait to get some snow .THANKS CROM!!!!!!!!!!!!!!!!!! :):):)
    TRDOFFROAD14 likes this.
  5. Jan 20, 2012 at 1:49 PM
    #45
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Boomer, Glad you enjoy the mod. :thumbsup: I absolutely love mine while off-roading. :)
  6. Feb 7, 2012 at 10:28 PM
    #46
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    someone do this to a 12 and tell me what wire it is! ours are different :-/
  7. Feb 11, 2012 at 10:34 AM
    #47
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    bump
  8. Feb 25, 2012 at 1:33 AM
    #48
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  9. Feb 27, 2012 at 11:10 AM
    #49
    Crom
    Nick
    San Diego, CA
    Millions
    Okay, The method in the OP should work for all locker trucks, prerunner included. What I believe happens with the diff lock switch is closed (ground signal provided), simulatniously the Skid Control ECU is notified and the 4WD ECU if present. There is a wiring junction point where the signal is split off I believe. In short it will work for Prerunners too.
  10. Feb 29, 2012 at 10:50 AM
    #50
    freeskier989
    freeskier989 Well-Known Member
    Mark
    Newport Beach, CA
    2012 Access Cab Off Road 4x4 V6
    ABS Switch Icon Stage 3
    Bump for the 2012 crew - would love to know how to do this on ours as well.
  11. Feb 29, 2012 at 10:56 AM
    #51
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Same way I did mine years ago. Cept I used the blue/yellow under the hood and fed in 12v instead of grounding
  12. Feb 29, 2012 at 12:48 PM
    #52
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    I did a no splice variation of this method and used a push button type. Since I do not use the TPMS system this is how I installed the switch:
  13. Feb 29, 2012 at 12:58 PM
    #53
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Hoping this question was directed at me.. no it is a push on/push off button
  14. Feb 29, 2012 at 1:29 PM
    #54
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    It dosnt re-engage with the OP's method??
  15. Feb 29, 2012 at 7:09 PM
    #55
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Mine does with the truck running or not. Curious to know
  16. Feb 29, 2012 at 8:22 PM
    #56
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Yup, you could set up a momentary switch. I grounded mine in 2005 and haven't looked back, abs sucks.
  17. Mar 8, 2012 at 11:57 AM
    #57
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Subd
    Going to most likely be doing this before my "No Pavement Run" coming up next weekend..
    Thanks for all the work put into this OP looks great and seems to work flawlessly!
    :cheers:
  18. Mar 8, 2012 at 11:59 AM
    #58
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    BTW nice pinstripen' job man! :D
  19. Mar 8, 2012 at 12:22 PM
    #59
    boomer6
    TN
    Tacoma TRD Offroad
    Did my 2011 Off road and it turns off and back on with truck running. You dont need to cycle the ignition.
  20. Mar 8, 2012 at 8:43 PM
    #60
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
