ABS light on? Which code reader?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, May 6, 2023.
  1. May 6, 2023 at 9:56 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    SD CA
    I’m guessing others have had this happen
    yellow ABS warning light occasionally comes on. Seems like no change in driving.
    maybe once every 1-2mo, on for a bit. Next key cycle or two, it’s gone.
    haven’t seen any torn ABS wheel speed sensor wires. But the truck is old. So I’m guessing they could use being removed to clean, white lithium grease, and reinstall. Especially the rears because idk if I ever touched those.
    I know I’ve “serviced” the fronts having to take them out to do work in the area.
    this has me want to find a good basic code reader, just in case for things like this, otherwise, or even friends cars, to get a baseline idea of what’s going on if there’s a MIL.
    I think it’ll probably be $30 on Amazon
  2. May 7, 2023 at 1:18 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I use a foxwell, it was cheap and works good. Resets all code airbag and ABS
  3. May 7, 2023 at 2:56 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    No cheap $30 code readers look at ABS so read the specs before you buy.
    Foxwell at Amazon and Walmart $120-130 model NT630 and does all codes and live data.
    Zurich (used to have Centech that I have) ZR11 for 130 at Harbor Freight same as Foxwell specs I believe. I've used mine like 4 times in 10 years.
    Note I see a $58 ZR4 online says reads ABS but not sure it really does and no airbag or live data so I would have to see in my hand to believe it.
    Best option borrow a friends or local TW members.
  4. May 8, 2023 at 8:07 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
