ABS light popped on - looking for probable reasons
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gshep54, Mar 19, 2016.
  1. Mar 19, 2016 at 9:00 AM
    gshep54
    gshep54 [OP] New Member
    Gordon
    2010 Toyota Tacoma TRD V-6 4WD Certified Pre-owned
    none
    My ABS warning light popped on for the first time ever a couple of days ago when I started up my truck. I also noticed that I couldn't shift into DRIVE. I restarted and the light did not reappear and I could shift as usual. Note of concern at that point. Yesterday I drove it about 5 minutes without issue THEN the ABS light popped on again for about 15 seconds and then went off. Higher level of concern now. I'm wondering what may be the likely reason for these events.
    I welcome thoughts from those who have had this experience obviously and those who are familiar with this issue.
    Thanks
  2. Mar 19, 2016 at 9:09 AM
    devkurf
    devkurf Member at Large
    midwest
    Did you have any work done recently where a wheel speed sensor could have been damaged?
  3. Mar 19, 2016 at 11:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the brake switch down on the brake pedal.
  4. Mar 19, 2016 at 1:17 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My abs light was kinda doing the same thing.
    My truck is manual so no shifting issues.
    I was just a little low on fluid and it was triggering my light. Found that here thanks TW! Sounds like the switch if it would not shift though. But I don't think the switch would trigger the abs light?
  5. Mar 19, 2016 at 1:32 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
