abs mod on 09 4cyl 4x4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttylerr, Jun 3, 2009.
  1. Jun 3, 2009 at 1:31 PM
    ttylerr
    ttylerr [OP] Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    I was just looking through the diy ABS, VSC, TRAC disable mod write up. Has anyone tried this with an 09 4cyl 4x4? I understand how it tricks the ABS computer into thinking the locker is engaged but does it work with the Auto LSD setup?
    Any help is appreciated! The ABS/TRAC in these things is way to picky for me...
  2. Jun 3, 2009 at 4:53 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    What exactly are you trying to achieve?
    There is a disable button on the lower left dash of my 2009....If you want no TRAC. just push the button once.
  3. Jun 16, 2009 at 10:12 AM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    krooks a little off topic..but what do you use to mount flags to your truck. i wanna do something like that but have no idea wher to begin, is there a thread for this..i cant fidn anything..tia
  4. Jun 16, 2009 at 3:07 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    The way i've figured out this whole system is like this:
    - In 2wd, the Trac Button Turns off Trac/VSC, Turns on the Auto LSD
    - In 4hi, it ONLY turns off Trac/VSC, no Auto LSD (why? no clue... seems this is where it'd be most important..?)
    - In 4lo, it turns off Trac/VSC and ABS, and Turns on Auto LSD
    ABS is only disabled in 4lo. I'm wondering if this mod will turn off the TRAC, ABS and VSC in any drive mode, and still work with the way the 09's are setup.
  5. Jan 2, 2010 at 8:01 PM
    Isthatahemi
    TRD OFF ROAD
    If you hold it down for 5 seconds while stopped, it shuts of everything, at least until you push the brake pedal. TRAC is 4 wheel Lsd, and it is the default mode in 4 WD
    No Lsd of of any type in 4Low
    The VSC button does what you ask.
