ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Sep 13, 2017 at 9:27 PM
    #2021
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    There are dozens of threads on how to do it on TW.
    bluezzy[QUOTED] and 303tacoma like this.
  2. Sep 14, 2017 at 4:26 AM
    #2022
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    oh, I know but I break out in a cold sweat when ever I even see a wire, I cant be cutting and splicing and so on. The truck would never run again.
  3. Sep 16, 2017 at 9:41 AM
    #2023
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Tires and a carefully lighter foot is all that's required... but I don't know how most people who don't know that cope with the abs. Most people don't run out and replace tires on their brand new trucks...let alone a Toyota truck. I don't know how their chief engineer can just ignore this problem.
  4. Jan 24, 2018 at 9:33 AM
    #2024
    rjames2
    rjames2 New Member
    2009 Tacoma TRD Off Road
    none
    113 pages of this topic being beaten to death, but it doesn't mean there isn't an issue. I have a 2009 automatic TRD off road and have already been in one accident where I'm confident it could have been avoided were it not for the ABS, and just missed being in another one this morning. Conditions in both cases were wet roads and doing less than 10mph.
    I've owned Tacoma trucks since 1988. Never had an issue coming to a stop in slick conditions. Also drove for a living for 15 years in all conditions, including ice and snow.
    ABS kicks in at low speed and i suddenly can't stop in what otherwise would have been very controlled or controllable situations.
    The only thing that saved me this morning was that I pumped the brakes. Totally counterintuitive to how ABS is supposed to work, as I understand it. a few months ago when i started to slide i mashed the brakes when I felt that traction was lost. Clearly I should have braked earlier, but that doesn't mean ABS should've locked the brakes. I even had time to put the vehicle in neutral while it was sliding to reduce forward force from the engine only to enjoy a slow motion collision with the car in front of me.
    I know it can be disabled by popping the fuse, but I do want ABS in case it's needed at higher speeds. At low speeds it's useless at best and dangerous at worst.
    Pickeledpigsfeet likes this.
  5. Jan 24, 2018 at 11:05 AM
    #2025
    SixSpeedTaco
    SixSpeedTaco Active Member
    07 Tacoma TRD OR DCSB
    Nothin But Dust
    I’m not gonna lie I didnt read all 113 pages so i’m sorry if this has been discussed already.
    But would you just be able to replace the abs “computer” or whatever controls it with an updated one from a newer taco that works better?
  6. Jan 24, 2018 at 12:46 PM
    #2026
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I remember coming home one afternoon when a snow storm had hit in my 99 Tacoma. I helped those that i could and i also passed many many people in the ditch (who had help) and not one second did I lose faith in my Tacomas ability to perform on bad roads and weather. My 2005 Tacoma I love but is a down right joke on bad roads with the ABS kicking at any speed over 5 mph. I wouldn't let anyone I cared about drive this truck in bad weather and that's due to the ABS on this truck.
  7. Jan 26, 2018 at 5:17 PM
    #2027
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Just pull the fuse, add a switch or whatever you have to do to make your truck safe. I pulled the fuse on my truck the first winter I had it and never put it back.
    Marc70 and JSB10 like this.
  8. Aug 20, 2018 at 7:27 PM
    #2028
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Anyone ever read end someone due to abs killing brake power?
  9. Aug 20, 2018 at 8:15 PM
    #2029
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Nope. I’d guess lots of police reports are wrote up though where people blame ABS for all sorts of things. I understand the complaints, but I have a hard time blaming ABS for accidents that are probably speed related.
    It takes 10 minutes of work on your driveway to override the ABS with a simple switch. Once I installed the TruTrac in my truck I wanted to be able to kill ABS, VSC, and TRAC on the trail on command. I was floored how it’s just one wire and a switch to make it happen in the second gen. For all the time people spend whining in here they could easily shut the whole system down if they wanted. I turn mine off when I want to throw dirt around and leave it on while on the road.
  10. Aug 20, 2018 at 8:19 PM
    #2030
    Oreo Cat
    Any links to how to kill abs on a 2006 trdor?
  11. Aug 20, 2018 at 8:22 PM
    #2031
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Oreo Cat[QUOTED] and knottyrope like this.
  12. Dec 16, 2018 at 8:13 AM
    #2032
    Lil red 02
    Lil red 02 Spendaholic
    Brent
    Sanford, Fl
    2005 Doublecab longbed
    Forgive my ignorance but theres alot of links and Im new here so forgive me in advance. I have a 2005 non trd and am trying ro figure out how to disable the ABS
  13. Dec 16, 2018 at 8:39 AM
    #2033
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pull the fuse, or relay. Make a switch in the circuit.
  14. Dec 16, 2018 at 8:40 AM
    #2034
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    BTW, my '97 E36 Bimmer has far superior ABS, than my '06 Taco.
  15. Dec 16, 2018 at 8:45 AM
    #2035
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My '01 and '10 Tacomas had/have great ABS brakes.
    My 2005 did not! Very dangerous on wet or dirt roads.
    I wonder what they did on some models to cause them not to work well?
    I took my '05 to the dealer about this and all I got was the standard "that's the way ABS works" answer. So happy my 2010 brakes work great like my 2001 did.
    Torspd likes this.
  16. Dec 16, 2018 at 10:45 AM
    #2036
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Signs of heavy winter:
    1. Early migration of Monarch butterfly
    2. Thick hair on back of cows necks
    3. Thicker-than-normal corn husks.
    4. Woodpeckers sharing a tree.
    5. Early arrival of the Snowy owl.
    6. Early departure of geese and ducks.
    7. Resurrection of dangerous ABS brakes thread on Tacoma World
    .劉煒, steelhd, fixer5000 and 10 others like this.
  17. Dec 16, 2018 at 10:50 AM
    #2037
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Jckdnls likes this.
  18. Dec 16, 2018 at 11:05 AM
    #2038
    MuddyJackson
    MuddyJackson Well-Known Member
    Eva
    Billings, Montana
    2006 Toyota Tacoma Base 4x4 6 speed
    My brakes have done similar things to me twice except the roads were damp, not even standing water or snow or ice. I almost blew through the intersection from a steep down hill. My abs light is on but randomly goes off, then randomly while I'm driving it reappears. No idea.
  19. Dec 16, 2018 at 11:17 AM
    #2039
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Brake fluid reservoir too low. Wheel speed sensor bad, or wiring. Bad wheel bearing (at that point though, it would be a catastrophic failure and undriveable.)
  20. Dec 16, 2018 at 11:28 AM
    #2040
    Lil red 02
    Brent
    Sanford, Fl
    Is there a link to that thread? Mine is not from snow or winter as I'm in Florida LOL. Mine is from me using my truck to hunt and then the Sugar Sand it will not stop it pulsates too much for me
