ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Dec 30, 2014 at 4:33 PM
    #981
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    U first, on your company vehicle. Show us how its done. Post video! :D
  2. Dec 30, 2014 at 4:37 PM
    #982
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Dec 30, 2014 at 4:38 PM
    #983
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  4. Dec 30, 2014 at 4:44 PM
    #984
    scocar
    scocar Patron of the Farts
    Robert, babe, welcome to the site. But you're gonna have a tough time here.
  5. Dec 30, 2014 at 4:46 PM
    #985
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ha ha considering that ABS prevents wheel lockup and reduces braking I would think people who like ABS would simply remove brakes and steer to avoid accidents.
    No brakes no wheel lockup all in steering. The rest of us would like to have brakes. :D
  6. Dec 30, 2014 at 6:04 PM
    #986
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    ABS=Anti-Stop Brake System.
  7. Dec 30, 2014 at 6:06 PM
    #987
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    That sucks man...
    One thing though.... sharp turn in 4hi ... going to cause binding and slipping of tires by nature. Already down on traction because of that, paired with high psi MT tires on a sheet of ice, not much you could do. I have had that happen without even touching the brakes simply due to the binding nature of not having a center diff.... sometimes its almost better to drive around in 2HI, and only flip to 4hi when necessary so turns can be made.
  8. Dec 30, 2014 at 6:07 PM
    #988
    Hugh Morron
    Bill
    I'm going to make boilo, see ya.
  9. Dec 30, 2014 at 6:09 PM
    #989
    BamaToy1997
    Bill
    Navarre, FL
    As usual, winter arrives and this thread explodes again. lol
    I am looking at the posted picture, and it distinctly shows 4 output lines, one to each wheel. Not sure what you are trying to indicate with the picture. There are two lines from the master cylinder, and 4 out. So that is a 4 wheel ABS system in the photo.
    It doesn't just use 4 wheel speed sensors. It also uses a yaw-rate sensor which measures deflection from straight line, so if you start to slide sideways, the yaw sensor can pick this up, and it is used as an input to the ABS and TCS system.
    To be fair, when driving on an icy road (As you described it) it wouldn't matter if you had ABS or not. If a tire cannot get traction on the ice, NOTHING is going to stop the truck short hitting an object. (as in this case) So while it did suck, I really don't think having or not having ABS would have changed anything in that specific situation. The ice and tires did not get along.
    Yes, believe it or not, even the manufacturers will tell you that in most cases ABS will increase the stopping distance, but will typically allow you to maintain more control of the vehicle. But yes, it DOES increase stopping distance in most all cases.
    So can a sheet of ice on the road, and/or bad tires. I don't care HOW skilled a person is at driving, if you are on icy road conditions, and your tires lose traction, NOTHING short of hitting something is going to stop your vehicle.
    You are not understanding the concept/operation of ABS. A sliding tire, (i.e. "locked up") gets hot quickly, and looses its traction. Loosing traction will remove your ability to steer or have any control. ABS is designed to apply the maximum amount of braking force to individual wheels, to the point of lockup, which gives you the BEST stopping in any condition. (Bar the heavy snow drifts where plowing is a factor)Not to mention that a major advantage that ABS does have that you CANNOT do, is it can apply the appropriate amount of brake force to EACH wheel, allowing those that have the most friction to get the most brake force, thus the better stopping ability. This allows a driver to have better control of their vehicle in these situations. Again, yes I have agreed that the Tacoma system has a lot of issues, but go drive a vehicle with a good ABS system, and you will then notice a REAL difference.
  10. Dec 30, 2014 at 7:14 PM
    #990
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    ^^ Save it for next year when this thread pops back up.
  11. Dec 30, 2014 at 7:15 PM
    #991
    OZ-T
    Peter North
    British Columbia
    WELCOME TO POS ABS
  12. Dec 30, 2014 at 7:16 PM
    #992
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  13. Dec 30, 2014 at 7:50 PM
    #993
    Rsamani
    Rsamani Well-Known Member
    Socal
    14 DBSB O/R 4x4
    not a lot
    and yes you are very knowledgable o great one:D
  14. Dec 30, 2014 at 8:27 PM
    #994
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    My attempt at ABS disable:
    :D
    D42551B8-68EA-456C-8F36-98659286D622_zps_b1d6422775a09becbc91008de1fbaf8f27a12e6a.jpg
  15. Dec 30, 2014 at 8:34 PM
    #995
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Admittedly, Not as macho looking as my Authorities though!
    6DE73270-903E-479E-96ED-58797A4F1DEE_zps_27a857d1a1a37452eb595b23c10003a2645b4912.jpg
  16. Dec 30, 2014 at 8:44 PM
    #996
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    *Freedom units.
  17. Dec 30, 2014 at 9:14 PM
    #997
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Nice garage BTW.
  18. Dec 30, 2014 at 9:32 PM
    #998
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Ha! I hope so.
  19. Dec 30, 2014 at 9:33 PM
    #999
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    :rofl:
  20. Dec 30, 2014 at 9:33 PM
    #1000
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you
