ABS on this truck is dangerous...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jan 4, 2010.
  1. Mar 16, 2015 at 6:00 PM
    #1741
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Ya know that could be related to the rear drums on the 2007 were not adjusted properly. As noted above the rear drums are self adjusting but only if you give the truck a good workout in reverse gear. I think the proper method is to put the ebrake about half engaged, then reverse the truck pumping the brakes for 30 yards and do that several times.
    There is also the problem with older trucks that people do not do a full brake system flush every few years or say 30,000 miles. It's surprising how much difference there is in braking power and performance after a FULL brake fluid flush. Not a bleeding at the axles, but a full flush with new fluid. Brake fluid wears out just like everything else. Rubber seals especially on drums get worn out and let some air into the system.
  2. Mar 16, 2015 at 6:06 PM
    #1742
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Nah, my 2007 had the ABS problem immediately on buying it.
  3. Mar 16, 2015 at 6:18 PM
    #1743
    monkeyface
    Colorado
    Shifting into neutral has been a tried and true method on slippery surfaces for about 100 years whether it's an auto or a manual. You're trying to STOP. If you're in gear that means you are still moving forward. It's a very simple concept, but apparently very difficult to grasp by some.
  4. Mar 16, 2015 at 6:44 PM
    #1744
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    I've been driving in snow for 20+ years and never once shifted into neutral and have never had an issue stopping until getting this 2014 Tacoma. The ABS system is garbage, end of story.
    Some of the people on this forum are so in love with their trucks that they fail to realize there are problems with the design of their precious trucks. Its like being stuck in a relationship with a crazy girl friend. :D
    It would be helpful if people tried to get the issue resolved rather than pretending like it doesn't exist or making excuses for the truck by assuming its driver error.
  5. Mar 16, 2015 at 7:39 PM
    #1745
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    herp a derp a diddly doo
  6. Mar 16, 2015 at 7:55 PM
    #1746
    monkeyface
    Colorado
    I see you're only up to 18000 posts now after rolling over at 92000 posts about six times since I've been on the board. You must have found a job. Congratulations. Maybe now you can save up some money and move out of your parent's basement pretty soon.
  7. Mar 16, 2015 at 7:57 PM
    #1747
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    :ohsnap:
    I see this thread still isn't going anywhere, I'll let myself back out.
  8. Mar 16, 2015 at 8:14 PM
    #1748
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I can tell it's difficult for you.
  9. Mar 16, 2015 at 8:17 PM
    #1749
    OZ-T
    Peter North
    British Columbia
    Maybe once
    Maybe I own the company
    Maybe my house is paid off
  10. Mar 16, 2015 at 8:21 PM
    #1750
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I was going to unsub from this thread because the back and forth is always the same. But the inevitable butt hurt that happens is usually entertaining.
  11. Mar 16, 2015 at 8:25 PM
    #1751
    Boone
    Boone, NC
    Airbags deployed
    Seems to be growing old, people that experienced it vs. the ones who have not.
  12. Mar 16, 2015 at 8:33 PM
    #1752
    OZ-T
    Peter North
    British Columbia
    and Bingo was his name-o
  13. Mar 16, 2015 at 8:45 PM
    #1753
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Agreed.
  14. Mar 16, 2015 at 10:47 PM
    #1754
    OZ-T
    Peter North
    British Columbia
    Maybe maybe
  15. Mar 17, 2015 at 3:41 AM
    #1755
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Only to return next winter...
  16. Mar 17, 2015 at 4:41 AM
    #1756
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Maybe we should talk about the weather instead...
  17. Mar 17, 2015 at 4:54 AM
    #1757
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
  18. Mar 28, 2015 at 6:54 PM
    #1758
    clamb
    clamb New Member
    Toronto ON
    2007 X-Runner
    ... I just found this thread after experiencing what some have written about here. Some background before I continue.. I've owned a number of modified vw prior to my x-runner (which I've owned now for 3 weeks). So I'm used to messing about with speed and quickly being able to reduce speeds down where/when it is necessary without issue.
    So with that said yesterday I took the rare opportunity to open up the truck a bit. Pulled over and let traffic behind me past and waited until I had ample room. Hit the accelerator and got up to around 100kph when I realized the person in the distant was in fact stopped waiting to turn left. I hit the brakes and was quite shocked when the truck seemed not to be slowing down in proportion to both my previous experience in my vw' s and in relation to the pressure on the brake pedal... It was an experience I'll be avoiding in the future. Pavement was dry but had it's share of bumps and dives... Felt like the brakes were inoperable to be honest. I may very well pull the abs fuse as there was no reason the truck needed that kind of distance to stop from those speeds.
  19. Mar 28, 2015 at 7:04 PM
    #1759
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Certainly try pulling the abs fuse and see if it makes a difference. Most of the issues people are having with the abs is that the system overreacts in snowy or icy conditions. Typically not on dry roads. VW's tend to handle quite well, so perhaps you're use to that.
    Also, the brakes may need maintenanced. Perhaps cutting the rotors or new ones if they're worn, plus a fluid flush.
  20. Mar 28, 2015 at 7:06 PM
    #1760
    OZ-T
    Peter North
    British Columbia
    Did you hear / feel the ABS pulse at all ?
