ABS rant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by T-Rex266, Feb 23, 2012.
  1. Feb 23, 2012 at 6:26 AM
    T-Rex266
    T-Rex266 [OP] SpaceX Director Moderator
    Elon
    Over the last few months I've had 3 life threatening incidents from what I believe is/was the cause of ABS engaging.
    Event #1- driving (after just making a right) down a hill and hit a ice patch. -ABS engaged and steered me into oncoming traffic.
    #2-this past weekend on our way up a one way long curvy hill ABS engaged and sent me into the other lane
    #3-on the way down that same road it engaged and again sent me into the other road.
    Not to mention all of the times that I make a turn on slush and the engine brakes are applied thus causing me to almost come to a complete stop while traffic is right behind me.
    If the ABS mod is done will the dash light come on? Who else is experiencing this? Thoughts?
  2. Feb 23, 2012 at 6:30 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  3. Feb 23, 2012 at 6:35 AM
    inouk
    inouk Well-Known Member
    Quick fix is to remove fuse #42 (50amp ABS). Light will come on but you'll stay alive.
    This is what I did.
    Oh, beware, you'll have some future post here that will tell you that you drove "too fast". Or, saying that without ABS, you'll have same effect. Be prepared.
  4. Feb 23, 2012 at 6:45 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    what you're describing is a combination of ABS/ TRAC issues. I drive pretty much all the time with the truck in auto LSD mode as I've had similar experiences trying to make a turn on a wet road only to find that the Trac system cuts engine power leaving me sitting in the middle of an intersection with cars heading for me instead of me spinning and making it through the intersection...
  5. Feb 23, 2012 at 7:28 AM
    T-Rex266
    Elon
    Sounds like me. Will the ABS mod eliminate this?
  6. Feb 23, 2012 at 7:29 AM
    T-Rex266
    Elon
    Thanks. That's fine.
  7. Feb 23, 2012 at 8:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you hear a beeper when this happens ?
  8. Feb 23, 2012 at 9:29 AM
    CtTaco
    Eric
    Connecticut
    most likely he wont as hes not sliding just spinning the wheels...the beeping occurs when you tilt the vehicle or its in a slide...
    The ABS mod would eliminate this, but you may lose all of the traction control systems. Personally I like having the trac system in snow, however I find it quite irritating most of the time so I automatically hit the VSC off button to put it in auto LSD as soon as I start the truck to eliminate the engine power being cut if the wheels spin...
  9. Feb 23, 2012 at 9:39 AM
    OZ-T
    Peter North
    British Columbia
    His description sounds like a VSC engagement more than an ABS engagement .
    If it is VSC it will feel like an ABS engagement in the brake pedal , but will be accompanied by a beeper and dash light .
  10. Feb 23, 2012 at 9:41 AM
    OZ-T
    Peter North
    British Columbia
    For example , ABS is unlikely to occur going UP a hill as described above
  11. Feb 23, 2012 at 11:57 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Agreed with OZ-T, uphill and abs sounds like bs.
    ABS is not really intended to make stopping distances shorter. It is intended to keep te wheels from locking up rendering your steering wheel useless. ABS cannot "steer" you anywhere as you've described. It merely let's you steer the vehicle where you've pointed the wheels.
  12. Feb 23, 2012 at 12:51 PM
    T-Rex266
    Elon
    Yes sir
  13. Feb 23, 2012 at 12:52 PM
    T-Rex266
    Elon
    Maybe just do this in snow? But even on dry pavement if it senses slippage then it veers me into the other lane
  14. Feb 23, 2012 at 12:56 PM
    OZ-T
    Peter North
    British Columbia
    Then it's not ABS , but VSC engaging .
    This is a fairly common side effect of lifting , the skid control ecu thinks you are going into a roll over or tail slide condition .
    As you go around a corner , the truck thinks the rear end is stepping out and tries to keep it from coming further around , unfortunately this results in you going straight on rather than turning
    You can get the VSC system recalibrated at the dealer , this works for most people
  15. Feb 23, 2012 at 1:04 PM
    OZ-T
    Peter North
    British Columbia
  16. Feb 23, 2012 at 1:08 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Dude, I did the disable mod last week with the blue/ yellow wire. Super easy and it turns on and off on the fly. I don't have a locker but I believe it works the same by fooling the computer.
  17. Feb 23, 2012 at 1:13 PM
    OZ-T
    Peter North
    British Columbia
    It's not ABS
  18. Feb 23, 2012 at 1:32 PM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Is this just a side effect of lifting, then? Or is it something that happens on unmodified trucks too?
    If there were Tacomas wildly veering into oncoming traffic every time they cornered on wet cement or ice I can't imagine there wouldn't be a recall?
  19. Feb 23, 2012 at 1:36 PM
    OZ-T
    Peter North
    British Columbia
  20. Feb 23, 2012 at 1:41 PM
    T-Rex266
    Elon
    Perhaps it's VSC then?
