ABS Scan Tool - OBDII Readers
Discussion in '1st Gen. Tacomas (1995-2004)' started by DblCabMN, Dec 21, 2020.
  1. Dec 21, 2020 at 12:05 PM
    DblCabMN
    DblCabMN [OP] Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Hi all,
    I've got my 2003 Tacoma and a 1999 4Runner both with ABS lights on. I don't want to pay a shop $100+ for each vehicle to tell me what the ABS codes are one time. (Local parts stores i've found only pull basic codes, not ABS for free.)
    I ordered a Foxwell NT630 Plus but it only pulled Chrysler/Ford/GM ABS data even after updating so i sent it back.
    I'm wonder what specific tool you're using in that $50-250 range that definitely pulls ABS codes from our older vehicles. I don't necessarily need the two-way bleeding functionality, i just need to know which wheel it's complaining about, or if it's the pump etc.
    Thanks!
  2. Dec 21, 2020 at 1:13 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    There is a way of finding ABS codes by jumping appropriate pins on OBD port.
    If I can find it I'll post the PDF for FSM or a link.
    Abeyancer likes this.
  3. Dec 21, 2020 at 1:16 PM
    Black DOG Lila
    Virginia
  4. Dec 21, 2020 at 1:17 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I use a scanner that is marketed by Bosch but it's just an Actron CP9695 that's in blue plastic. You'll need the 9695 model to be able to pull ABS codes from a toyota of our vintage.. I think Amazon has em for around 280 bucks
    Black DOG Lila likes this.
  5. Dec 21, 2020 at 2:41 PM
    slodoug
    slodoug Well-Known Member
    I have a scangauge II on my dash, tells me any code and lets me clear it.
  6. Jan 7, 2021 at 8:37 AM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    Thanks all,
    Yeah i had used the search function but still have trouble locating the actual steps. Lots of people just saying, "I jumped the pins." with no further explanation.
    I called Actron and spoke with a tech rep about the C9680 and C9695. She verified the only difference between the two in regards to ABS data is the 'Datastream' functionality. Though beyond "it can read live data of what the system is doing" she was unable to provide more detail about what exactly it would pull (per-sensor voltage, pump actuation, etc.) Sounds like it could be nice, but the ~$150 increase in price between the two models doesn't seem worth it for me personally.
    She was kind enough to check the supported vehicles for me as well. It looks like they'll both do ABS codes for my Tacoma but not - or more limited - reading of the 1999 4runner. I might pick up the C6980 as the base ABS functionality is enough for the Tacoma and some of our other early-2000 vehicles.
    I also called ScanGauge and asked about the ABS code functionality, the rep stated it does not pull ABS Codes as the tool doesn't communicate on those pins. Its solely traditional diagnostic/Pxxxxx codes and sensors.
    *EDIT - i found relevant info here:
    https://www.tacomaworld.com/threads/how-to-pull-abs-codes.205231/
    "In order to pull codes, you need to connect pins 4 and 13 and then turn the key to the on position. This will flash the codes."
    SR-71A, Wyoming09 and turbodb like this.
