ABS was gone for unknown reason - truck end up in snow bank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, Feb 12, 2011.
  1. Feb 12, 2011 at 3:07 PM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    My truck slid off into the ditch. Wife said there was no ABS so 4 wheels locked while truck was descending iced up hill. Now, I would probably dismiss that if not for the fact that I saw it with my own eyes and test drove it after got truck out of the ditch.
    There was no ABS action until I decided to test sliding backwards in 4hi. Only then ABS kicked in and worked afterwords.
    No errors, No ABS light, nothing. I have scan gauge and and it did not pickup any error codes.
    Weird $hit and reason why I hate electronics. Looked at FSM but not seeing how would ABS manage to turn itself off with out displaying light on the dash.
    Any ideas?
    Personally I would love to disable that crap permanently but wife says she needs it.I don't see a point of having it ON if its not reliable.
  2. Feb 12, 2011 at 3:19 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Sounds like another group lawsuit against Toyota in the making. This time for lack of rapid deceleration.:stirthepot::stirthepot:
  3. Feb 12, 2011 at 3:27 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Interesting , this is why I try not to rely on ABS and just slow down / gear down when I'm driving in snow.
    Having said that , the system should still have engaged .
    I assume damaged wires would have thrown a code .
    Odd .
  4. Feb 12, 2011 at 3:46 PM
    BlueT
    NorthEast
    If more people ends up in the ditch because of that I am sure somebody will sue.
    If ABS light is ON then there is malfunction so that would be easy to solve, just pull the code. But light never went ON and scangauge did not pick up anything so this defiently was not regular failure.
    whippersnapper02 - Not sure if you relize but the same thing controls traction system so if that happens when you offroad you better have long towstrap.
    Also truck knows when has 4 wheels locked since all 2gens have deceleration sensor. Plus you never have all 4 wheels locking at the same time. When ABS kicked back ON I went the same route and it worked fine every time
    I hear you OZ-T, same with me I don't expect for this thing to work so I brake the old school way.
  5. Feb 12, 2011 at 3:48 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    its possible that the brakes were overheated in which case it could shut off.
  6. Feb 12, 2011 at 3:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Just thinking here...
    Is it possible that your wife was pumping the brakes? Or, she didn't have the brakes on long enough in any given period of time? (ABS won't work if you're pumping the brakes)
    Or....I'm also wondering - if you don't have your foot smashed on the brakes, does the ABS still function when only half the pedal is depressed?
  7. Feb 12, 2011 at 4:07 PM
    BlueT
    NorthEast
    Definetly no, its 32F here and it happened at the beginning of the trip so whole system would be cold.
    She definitely was not pumping brakes I did see all 4 wheels go from turning to full lockup and stayed that way until nice crunch sound :mad:
    Yes, ABS engages regardless of how much you brake, it does it as soon any wheel locks up. I tested afterwords and there was no way to get ABS to work. I was sliding truck left and right and ABS would not engage. I finally put in 4hi and slided backwards , only after I did that, ABS kicked in and worked since then.
    I doubt Toyota will be able to get that solved since there are no error codes or anything else. I am going to give corporate Toyota a call and see if they have any ideas. I dont wont to take trip to the dealer and get my computer flashed.
  8. Feb 12, 2011 at 5:57 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Pretty sure abs has limits. I've locked mine up recently and purposefully. Love pulling off onto the wet grass and hammering the brake. If its slick enough to slide off a road, its probably slick enough to defeat abs. Once all the tires lock, you're stopped in its eyes.
    Nice evidence that people don't know how to drive anymore. "what do I do if brakes lock" Press harder?
    Believe its emblazoned in the manual; but its hidden underneath a car seat so I'm not going for it.
    Should what is said to have happened happened like is said, it may have gotten confused after whatever happened happened and took a few revs to get back to normal.
    Not a big fan of the anti-stop brake system myself. More you want to stop the less it seems to work. Where is this world the federal government thinks we live in where people swerve under braking. Maybe its driving and motorcycle training that keeps me off the brakes while swerving. Brake, swerve, brake. Ingrained into my soul. Couldn't swerve with foot on the brakes any more than sneeze with my eyes open. I'll take my stopping distance short thank you. I don't drive at things I need to swerve around I want as little energy as possible in an impact, not more control while braking in a straight line.
  9. Feb 13, 2011 at 5:44 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I would suspect iced up sensors...
    Howard
  10. Feb 13, 2011 at 6:01 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    #1 The vehicle speed must reach above 12 mph before the ABS turns on
    #2 Malfuction of the ABS will cause the ABS control module to shut off or inhibit the system.
    #3 Loss of fluid in the brake master cyl will disable the ABS
    Do Not exceed the speed limit on wet and slippery roads
    The ABS DOES NOT operate effectively when the limits of gripping performance have been exceeded.
    SLOW DOWN
    If the vehicle hydroplanes while driving at HIGH SPEED on wet or slick roads, the ABS doesn't work effectively
    The ABS Warning light indicates a malfuction in the ABS or the brake assist system
    The ABS IS NOT designed to shorten the vehicles stopping distance.
    Always maintain a safe distance from the vehicle in front of you in the following situations:
    When driving on dirt, gravel, or snow covered roads
    When driving over bumps in the road
    When driving over potholes or uneven roads.
    SLOW DOWN!
    Don't blame the vehicle for your inadequate driving skills on slippery roads
  11. Feb 14, 2011 at 10:15 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Are you positive it wasn't that the ABS did in fact come on and the damn thing just wouldn't stop? I put a switch inline with the fuse for the ABS system on mine because I got tired of not being able to stop the truck in the snow/ice. I swear the system just can't make up it's mind at low speeds. High speeds it's nice to have. Low speeds once it engages it's like you lifted your foot right off the brake pedal. Now when the roads are bad I flip the switch and I know I can stop. Just like the 98 I had to wait forever to arrive without ABS brakes.
  12. Feb 14, 2011 at 10:37 AM
    BlueT
    NorthEast
    Positive. Wife was driving I was watching outside from 10 feet away. All 4 locked and stayed locked. No sound either. When I tested the same thing happened no ABS whatsoever. No sound and no brake action (No ABS light either). Its like truck never had one.
    ha ha it would be cool to find out how to disable ABS with out even warning light ON. :D This way no problem with inspections.
  13. Feb 14, 2011 at 11:25 AM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    ABS doesn't work when the roads are iced up? http://www.ehow.com/about_6162289_do-brakes-work-ice-snow_.html
    "Under severe conditions when the entire road is covered with ice, all four wheels may lock simultaneously. Unless at least one wheel is turning, the ABS will react as if the vehicle has stopped. When this occurs, the ABS is defeated, and the driver will need to go back to the pumping technique."
  14. Feb 14, 2011 at 11:32 AM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
  15. Feb 14, 2011 at 1:30 PM
    Derpy Derek
    Derek
    Brookings, OR
    It's not a complete fail though, it has saved my ass on two occasions when the ground was wet from rain. 4wd, ABS, lockers, or anything else- ice is sadly still a nightmare
  16. Feb 14, 2011 at 1:39 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Ice = Hockey Puck
    Personally I like having ABS there, but know that my driving style has a greater influence on how fast I stop than the safety equipment.
  17. Feb 14, 2011 at 2:06 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    ABS is not a fail, it is very useful tool
    now if you are DEPENDING on ABS to stop you
    then you have failed as a driver.
    In the service we called it 11-1-A-799
    aka : Operater Error
  18. Feb 14, 2011 at 2:23 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    i have found that the ABS doesn't work below a certain speed.
  19. Feb 14, 2011 at 2:40 PM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    I suspect the low sPeed is what caused it not to turn on (normal operation like stated earlier). What was the speed of travel?
  20. Feb 14, 2011 at 2:44 PM
    mattygabe
    mattygabe Well-Known Member
    Western PA
    2011 Access Cab SR5
    Access Limited Soft Rollup Tonneau Cover
    I'm sorry, but this whole, "I hate digital things, just give me the way old things are" is completely bunk. If you love the way "old things are", then go buy a 1960 Chrysler Saratoga and let me know how your wife does with winter driving in that thing.
    ABS doesn't deal with stopping distance, its purpose is to help maintain the driver's control over the direction of the vehicle. Saying you'd rather pump the brakes yourself is ridiculous, too. 10 times out of 10, the ABS system will out-perform you in terms of the amount of control is returned to the driver. And the times that the ABS system is defeated - that's why YOU are the driver instead of the computer - you should be able to tell when you need to start pumping the brakes.
    I don't buy the whole "Blame the technology, give me the basics and I'll do the rest". That's a bunk theory and it creates an allowance for drivers to not learn how to properly control a vehicle.
    The icy road is a pretty sucky condition, and it doesn't happen often, so I don't think it's ridiculous that your wife didn't know how to react properly. But I also don't think it gives anyone the right to blame the technology. Toyota never said the ABS system would work 100% of the time, and to not know how to properly operate your vehicle. Onus is on you (or your wife).
