AC Belt Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Feb 21, 2008.
  1. Feb 21, 2008 at 4:04 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Hey fellas, I have an 04 Double-Cab PreRunner 3.4L V6 and was wondering how to go about adjusting the tension on my AC compressor belt. Seems a little too loose, and I have got some squeeling going on. Looks like a bitch trying to get at anything from above in the engine compartment. Do you make this adjustment from below by dropping the skid plates under the engine to gain access, or does this adjustment have to be made from under the hood?
    Thanks.
  2. Feb 21, 2008 at 8:22 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I just recently put new belts on mine so Ill give you the run down on how I did mine yes it is a bitch to get it lol
    Ok first yes drop your skid plates then you have to loosen the bolt that holds that pulley its the bolt thats in the center of the pulley
    there is an adjuster that sits at an angle to the right of it if your looking at the front of the truck turn that I think it was clock wise don't think its reverse threaded and tighten it up BUT DON'T FORGET to tighten that pulley bolt back up
  3. Feb 22, 2008 at 2:59 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Thanks, Man.
