AC cold to warm in an hour
Discussion in '1st Gen. Tacomas (1995-2004)' started by Vsquared, Jun 11, 2019.
  1. Jun 11, 2019 at 9:35 AM
    Vsquared
    Vsquared [OP] New Member
    Victor
    2003 Tundra X-Cab V6 Automatic
    N/A
    I have a 2003 V6 xcab with auto transmission with 114k.
    My operating temp will drop to almost 30 degrees and hold for 30 minutes or so.
    With in an hour it will be 60 degrees. Also the volume or speed of the air out of the vents seems to drop. My mechanic fixed .25 lb low on freon and a leaking schrader valve.
    But it is still doing the same thing.
    If I shut off for a few hours it stars the process all over.
    Also I notice that when i turn control to defrost the ac works , even if then button is off
  2. Jun 11, 2019 at 10:10 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    First off, the Defrost activating the A/C is normal for every A/C system.
    Second, assuming the pressures are good... Have you checked with the mechanic who repaired the A/C in the first place?
    It could be an accumulation of junk between the A/C Condensor and the Radiator.
    Abeyancer likes this.
  3. Jun 11, 2019 at 10:12 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    All cars with AC turn on when the defrost is activated, the vehicle is using the AC compressor to create dry air to blow on your windshield, yes it's cold... but it's because it's dry that it does it.
    Is the condenser free of debris? If the system overwork itself from not being able to dissipate the heat you'll get the symptoms you're describing
  4. Jun 11, 2019 at 10:12 AM
    Abeyancer
    Jimmie
    PNW
    You type faster than I do :rofl:
    OneWheelPeel[QUOTED] likes this.
  5. Jun 11, 2019 at 12:58 PM
    Glamisman
    Glamisman Well-Known Member
    if the air discharge out of the vents is 30 degrees that is too cold. Off the top of my head, there is a possibility that the evaporator has frozen over and you have to wait until it thaws. When it stops working check the evap drain to see if it is pluged or is still draining.
  6. Jun 11, 2019 at 3:28 PM
    trdproven
    trdproven Well-Known Member
    i would double check if your system is filled correctly. too high or too low gives some erratic HVAC issues.
  7. Jun 11, 2019 at 3:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Definitely take it back to the mechanic and tell him: "you know that thing you said would fix my problem? It didn't fix my problem and I don't think I should pay for that."
  8. Jun 11, 2019 at 3:53 PM
    OneWheelPeel
    Phoenix, AZ
    Did he replace the Dryer as well? - Sometimes, you will never remove all the moisture that accumulated in the system when there is a leak (though it sounds like yours didnt totally evacuate) and some gets stored in the dryer. Purge and fill doesn't always result in factory like results.
    cruiserguy likes this.
  9. Jun 12, 2019 at 3:37 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Sounds like the evaporator coil is freezing up. Have you checked your condensate drain?
    Clearwater Bill likes this.
  10. Jun 12, 2019 at 3:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    The thermistor on the face of the evap has failed allowing the evap to ice over as other suggest.
    The evap should operate about 34-36* then the thermistor shuts off the compressor till the temp rises to something around 40*, then allows the compressor to engage again.
    The ice that forms stops air flow. You can make it last a 'little' longer by selecting outside air instead of recirc until you get it fixed.
  11. Jun 12, 2019 at 7:06 AM
    Vsquared
    Victor
    N/A
    Thanks for all the input . I will look into these suggestions and get back to you. Good news it does not sound like it will be too expensive.
  12. Jun 12, 2019 at 7:11 AM
    Vsquared
    Victor
    N/A
    the average temp is 40 so I always run outside till it warms up.
    I will have to look up where the evaporator thermistor are located
