ac compressor help
Discussion in 'Technical Chat' started by tacomarich, Oct 24, 2009.
  1. Oct 24, 2009 at 4:28 PM
    tacomarich
    tacomarich [OP] luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    ac compressor wont engage with amber ac light button engaged but fresh air and circulate levels, appear to run at normal temps. i checked the 7.5vlt amp fuse and replaced it with a 10amp, no change. put 7.5 back and same issue. im thinking its either the belt or the compressor ground or it ceased under load. heard it grind a few times, when engaging. had 37k miles at that time but has been quite since.
    only 41k miles now and would think these compressors last? how many have had similar problems with their compressors? im thinking maybe i kicked some dirt up in the compressor and it ceased. i might try pressure washing around those areas. anyone hear if they have a safety cut off to prevent it from ceasing under any stress loads?
  2. Oct 24, 2009 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If its out of refridgerant it wont engauge.
  3. Oct 24, 2009 at 4:32 PM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    sweet. cool man, where do i check for the refridgerant levels and is this something i can do myself? or go get an ac tune or have it covered under warranty? btw i read your post and vid post on that cabin air filter replacement diy and it worked great! :D
  4. Oct 24, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure if its covered under warranty. You can get "Do it Yourself" stuff at Walmart, but if you lost refrigerant, odds are, you have a leak someplace. I dont know much about AC stuff, so I would take it into a shop.
  5. Oct 24, 2009 at 5:33 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    If you heard a grind while engaging, I'd be willing to bet the clutch is bad.
  6. Oct 24, 2009 at 6:10 PM
    kooltacos
    kooltacos New Member
    South Carolina
    99 xtracab djm 3-4 drop on rimps
    you should not have any issues with your ac compressor at 41k. The only time I see mechanical issues is on vehicles with well over 200K. That's on Toyota trucks anyway. There are exceptions like if you run your truck through a mud hole everyday, that could be bad for a lot of things.
  7. Oct 24, 2009 at 6:23 PM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    the clutch on the compressor or the clutch on my transmission?
  8. Oct 24, 2009 at 6:24 PM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    well had to floor it out of this small ditch and got out in 4lo locked but if i was running my air i reved the engine a few times and burnt the clutch trying to get out.
  9. Oct 25, 2009 at 2:36 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Clutch on the compressor. It is what engages and disengages the compressor.
  10. Oct 25, 2009 at 5:08 PM
    shook0002
    Joe
    Philly
    Yes, clutch on the compressor. If you off road it you may have gotten water and some sand in there.
  11. Oct 25, 2009 at 6:35 PM
    tacomarich
    rich
    arizona
    trd 4x4 offroad
    im thinking maybe thats what happened. not seeing too much dirt in there though but i think ill pressure wash the inside engine area and the under carriage and check before i take it into warranty services
