AC Compressor Not engaging
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, May 23, 2016.
  1. May 23, 2016 at 1:42 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey guys,
    So my AC has been blowing warm since October, I didn't bother recharging it because it was winter. I know I have a slow leak somewhere so I bought R134 with uv dye in it so I can spot the leak. I noticed as I was recharging it that it got to the correct pressure extremely quickly, like the compressor was not engaged.
    I know that the compressor is fine because it worked last year well, and I had no issues. How can I get the compressor to properly engage?
    Thanks
  2. May 23, 2016 at 2:53 PM
    Tjsingle26
    Tom
    PA
    The temp here is about 65, the psi of the system is around 30.
  3. May 23, 2016 at 3:01 PM
    Tjsingle26
    Tom
    PA
    This is how it look when the engine is running with AC on.
    The dryer near the front grill does not show any r134 moving through the system via the glass.
    Prior when the AC worked, I would click the button and you could hear the compressor kick on, now it's nothing
  4. May 23, 2016 at 5:58 PM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    Press on on the other hose fitting, low pressure side, to purge some of the air in the system.
    Not a proper way, but it can release enough of the air in the system, to get you to where you can find the leak.
    The sight glass is great tool to see that you are getting a charge .
    Only other choice, a shop that specializes in a/c , and repairs.
    Thing is , was able to find my leak, and make the repair, by doing as I described.
    Disclaimer, no man made global warming was created using this technic, nor animals or children harmed.
    Bivouac likes this.
  5. May 23, 2016 at 7:06 PM
    Tjsingle26
    Tom
    PA
    There has to be air in the system because none of the refrigerant is circulating
  6. May 24, 2016 at 8:31 AM
    Tjsingle26
    Tom
    PA
    I think that there may be little to know refrigerant in the system, what's the best way to get it flowing again? I don't know if it could run dry
  7. May 24, 2016 at 8:40 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Verify that the A/C compressor clutch is working.
    Unplug the connector on top of the compressor and apply 12 volts and see if it clicks.
    nobuenobeast likes this.
  8. May 24, 2016 at 10:12 AM
    Tjsingle26
    Tom
    PA
    I'm no expert in electrical, what's the best way to apply 12v to the connector?
  9. May 24, 2016 at 10:19 AM
    mavfox
    mavfox Well-Known Member
    SFL
    2013 AC TRDOR/07 FJC
    ARB Deluxe bullbar, OME 886 w/ Dakars, Warn Winch, Safari Snorkel, Tepui RTT.
    Use the battery
  10. May 24, 2016 at 10:37 AM
    tan4x4
    Rick
    Folsom, CA
    Hmmmm.
    You need a length of INSULATED wire, around 4-feet long.
    Disconnect the connector from the compressor (which is grounded thru its case).
    YOU make contact with one end of the wire to the exposed terminal (leading to the compressor).
    Have a helper make contact with the other end of the wire to the positive (red) post of the trucks battery.
    At the moment when both ends are in contact, 12v is applied to the clutch, and it should 'click'.
    If it doesn't click, then the compressor clutch is bad.
    If it does click, then the A/C computer is not sending the signal to the compressor clutch to turn it on.
  11. May 24, 2016 at 11:04 AM
    Tjsingle26
    Tom
    PA
    Alright thank you, I'll try that out.
  12. May 31, 2016 at 7:46 PM
    Tjsingle26
    Tom
    PA
    Got the compressor clutch to engage. I will be looking for leaks this weekend
  13. Apr 9, 2019 at 12:11 PM
    xSmokey
    xSmokey Active Member
    Maverick
    2010 White Tacoma SR5
    None :(
    So for 1st gens is 30psi normal? Because, on the 2nd gens at least, 30psi is really low.
  14. May 13, 2023 at 1:29 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
  15. May 15, 2023 at 9:19 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The reason your clutch is not pulling in one of the pressure switches is open.
    You are using Manifold gauges so your able to read both high and low pressure
    It really helps if you pulled a vacuum since your system is completely empty .
    That draws the refrigerant into the system.
    Don`t forget the oil for the compressor.
    Good luck!
