AC Fan only work on HIGH
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoLimo, Jun 16, 2016.
  1. Jun 16, 2016 at 3:51 PM
    TacoLimo
    TacoLimo [OP] New Member
    2006 Crew Cab Long Bed
    ARE Shell with TINT all around
    My AC fan on my 06 Tacoma only works when the switch is on HIGH! Any ideas why?
  2. Jun 16, 2016 at 4:06 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  3. Jun 16, 2016 at 4:11 PM
    TacoLimo
    Can you tell me where the resistor is in the truck?
  4. Jun 16, 2016 at 4:14 PM
    Drivesector
    TRD sport
    Look at the links, there is a diagram of the parts.
  5. Jun 16, 2016 at 4:17 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    In the passenger footwell there is a electrical connection, take it apart and see if you see any signs of heat/burning.
    My cousins 2005 tacoma had the issue of the fan blowing on high only (Or off) and the heat in the connection had warped one of the pins away from the contact, bend it back and you'll be good for a few years.
  6. Jul 12, 2016 at 3:39 PM
    88incher
    88incher Member
    Nick
    2006 Tacoma
    None yet
    This fixed mine for now I will have to see how long it lasts. I put some dielectric goo on the connection. The schetchy thing is why do the wires get hot?
  7. Jul 12, 2016 at 4:23 PM
    Drivesector
    TRD sport
    Loose connections on the plug cause more amps to be drawn causing heat.
  8. Jul 12, 2016 at 4:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, that is backwards.
    The loose connection causes a higher resistance to current flow ( less Current ) and the extra energy supplied from the battery is converted to heat.
  9. Jul 12, 2016 at 4:57 PM
    Drivesector
    TRD sport
    I stand corrected.
  10. Jul 12, 2016 at 5:49 PM
    88incher
    88incher Member
    Nick
    2006 Tacoma
    None yet
    Got it so spreading the prongs should stop that. Thanks
  11. Jul 12, 2016 at 7:57 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Toyota does sell a replacement cable end if needed. There is a thread here somewhere that has a part number. You will either need to Butt Splice the wires or solder and heat shrink them.
    Plug = 82141-04M40
    Resistor = 87138-04052
    Here it is:
    SCFirefighter likes this.
  12. Aug 1, 2016 at 7:14 PM
    Taco Salad Sport
    Taco Salad Sport Well-Known Member
    Castle Rock, CO
    2012 Sport DCSB 4x4
    I have this same issue. Is it still cool to run it in high until I replace the resistor + harness? Can any electrical gurus explain why this still works in high?
  13. Aug 1, 2016 at 7:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    In the lower speeds the current is routed through the various resistors to lower the current and reduce the speed of the fan. In high speed it is not routed through the resistors.
  14. Aug 1, 2016 at 9:09 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    Marked thread - you guys are awesome!
  15. Aug 1, 2016 at 9:15 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    It's a Toyota.... They all do that!
    I have owned 3 Toyotas prior to this one...
    It doesn't hurt anything, it just has 2 speeds.
    Taco Salad Sport likes this.
  16. Aug 1, 2016 at 9:56 PM
    TakDwn
    PA
    Yep - On and Off. LOL
  17. Aug 2, 2016 at 5:06 AM
    Taco Salad Sport
    Castle Rock, CO
    2012 Sport DCSB 4x4
    Thanks!
  18. Dec 13, 2016 at 7:03 AM
    pmosin
    pmosin Well-Known Member
    SoCal
    07 Access Cab 4x4 TRD 6spd
    ARE Camper shell
    Subbed, thanks for sharing the diagram links & parts info
  19. Dec 13, 2016 at 7:52 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
