AC/Heater keeps going in n out. Motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xguntherc, Dec 16, 2016.
  1. Dec 17, 2016 at 1:52 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    its possible, but I'm no expert. Just relaying information gathered upon reading different threads. Is everything working properly?
  2. Dec 17, 2016 at 1:59 PM
    Fuelman
    Fuelman Well-Known Member
    Winchester VA
    2014 Taco DCLB Sr5 4x4
    Ultraguage
    The pins on my resistor were the problem. It's a sloppy fit, I bent them slightly towards the contacts in the female connector no more problem. YMMV
    Pabloeeto and Bocsy44 like this.
  3. Dec 18, 2016 at 8:08 AM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Yeah everything works fine. I did have a weird ticking several months ago that I was assuming was the blower motor but it has all gone away. The only thing that isn't working right, besides the scorched connector, is the panel lighting is really dim and can't be controlled by the dimmer switch. I do have the illumination wires tapped into for some switch lighting, so that maybe it.
  4. Dec 18, 2016 at 8:36 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    well you're lucky the ticking went away, its really annoying to hear haha that is indeed the motor. burnt connector I would say that there's a loose connection somewhere causing extra resistance in the circuit. seems like most people are having connection issues at the resistor. Dim lighting could be caused by the power draw from your switch lighting. you could test that theory by removing it temporarily if it really bothers you and isn't a PITA to do lol
  5. Dec 20, 2016 at 10:05 AM
    xguntherc
    xguntherc [OP] Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Yeah if you're patched into the lighting they'll be dim because they aren't getting the same power flow as before. Shouldn't be too much an issue unless fuses keep blowing.
    And my motor always had a really light ticking on the lowest setting. I could hear it in early summer/winter when only needing to barely use the first speed setting. Anything higher and it drowns it out.
    But now, now it slowly tick tick tick until it reaches a speed it needs to push air. I can hear it struggling to turn. And I hear the ticking on the first three settings for air. It's obviously going out. I have the newer OEM Blower Motor 87103-04044 on order. (btw, the older -04043 is the original part) The 04044 is the newer model that shouldn't have ticking. For anyone else replacing the blower motor. I'll post my results over the weekend.
    Bocsy44 likes this.
  6. Dec 26, 2016 at 11:12 AM
    xguntherc
    Cory
    East Dallas
    Toyotaonlineparts.com has the blower for $91. Decent price and cheaper than Amazon.. debating buying it with them, or from Amazon who I know will ship fast.
    Anyone order from that site before?
  7. Dec 27, 2016 at 11:12 AM
    xguntherc
    Cory
    East Dallas
    Think I'll pull the trigger and hope they ship fast. Says it's OEM
  8. Dec 27, 2016 at 12:34 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    as long as its the same part number, cant hurt to save a few bucks
  9. Nov 18, 2018 at 1:42 PM
    xguntherc
    Cory
    East Dallas
    Oh.. fyi. I got the motor, swap was super easy.. been running great for 2 years. No issues.
