ac noise
Discussion in '4 Cylinder' started by dayNnite4, Jul 21, 2011.
  1. Jul 21, 2011 at 9:42 PM
    dayNnite4
    dayNnite4 [OP] We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    has anyone heard a chattering noise coming from i assume the condenser when the air conditioning is on?
  2. Jul 21, 2011 at 9:47 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Yep, normal
  3. Jul 21, 2011 at 11:33 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    mine does it sounds like fucking shit too!!!!!
    i noticed something the other day though. if i press the clutch in my sound goes away. when i let the clutch back out the noise comes right back. it seems to be much louder when the air conditioner is on though.
  4. Jul 21, 2011 at 11:41 PM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    Its the fan hitting the fire wall.
  5. Jul 21, 2011 at 11:43 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    sounds like a throw out bearing to me at least on my truck it does mine clatters like mad and my truck only has like 6k on the odometer!
    never had any shit like this on a new car or truck before it's very strange.
  6. Jul 22, 2011 at 10:19 AM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    oh well..winters coming soon anyway. fuck this weather, over 100 in north jersey today!!
  7. Jul 22, 2011 at 11:06 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    lol i like the warmer weather but, it's horrible in here in southern nj. dude my thermometer on my kitchen window say's 105!
  8. Jul 22, 2011 at 5:35 PM
    Yota1
    Yota1 Well-Known Member
    is it when you are in neutral and parked? mine really sounds like a diesel when ac is on parked and in neutral, get a real low vibration that sounds like it is coming from mid chassis
  9. Aug 5, 2011 at 6:40 AM
    carattini
    carattini Well-Known Member
    David
    Puerto Rico
    08 base model
    I have the same problem i have a 2008 5 LUG It does it with or without tha AC but is Bad with Ac On. and when the clutch is pressed is less sound. I don't know what it is but my money is on throw bearing. When I have money I will change the hole clutch. :cool:
  10. Aug 5, 2011 at 6:24 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    mine makes the noise regardless of the clutch position..is sounds like the compressor/condenser/something bc it will stop for a little when come back..like it cycles
  11. Aug 5, 2011 at 6:26 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    check cabin filter, mine was making some weird noise, it was just a leaf up in there.
  12. Aug 6, 2011 at 2:47 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    ill check that out, thanks!
  13. Aug 6, 2011 at 11:26 PM
    DeuceRooster
    DeuceRooster Well-Known Member
    Kentucky
    2011 RC 4X4
    I have basically the same truck as you (just in RC form) and with just 1500 miles on mine it's making similar noises. Usually can't hear them inside the cab but outside you certainly can.
  14. Aug 8, 2011 at 5:46 PM
    dayNnite4
    Nick
    Southern NH
    '11 4x4 5-speed AC
    yeah im thinking if this many people hear the same thing, it cant be anything horrible or abnormal. like i said i feel like its the condenser or something im not worried. thats wat warranties r for haha
  15. Aug 9, 2011 at 10:26 AM
    pigger
    pigger Well-Known Member
    Greg
    Rio Rathole
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, big-ass bumpers, older-than-dirt owner
    My '04 makes a lot of noise from the compressor clutch, and also occasionally "glitches" (feels like the engine almost stops) when the AC's on.
    It's not the idler pulley. I sprayed some silicone behind the compressor pulley and it went away, but came back somewhat after a desert ride.
    I'm going to spray it again, and see how long it stays quiet.
  16. Aug 11, 2011 at 6:42 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Its happened with my truck since day one. I took it to the dealer right away because it did not sound normal to me. I find with the A/C on and clutch in, the noise goes away, but in neutral with the A/C on and clutch out the noise is there, and as some have mentioned, its sounds like a TO bearing is going out. Still doing it after 37,000 miles...:confused:
  17. Aug 11, 2011 at 7:32 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Its a 4 cyl thing, you would not understand :D
    No, really the 4.0's do not have this issue.
  18. Aug 11, 2011 at 1:08 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Mine has it...and yes, it sounds like a diesel when idling.
  19. Aug 11, 2011 at 2:49 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
  20. Aug 12, 2011 at 5:22 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Seems many of us hear it outside of the truck during idle, too; therefore, the clutch is not engaged.
