AC not blowing Air! Any Suggestions on what the problem is?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bytor78, Jun 10, 2012.
  1. Jun 10, 2012 at 6:43 AM
    bytor78
    bytor78 [OP] Member
    PreRunner TRD
    My 2006 Tacoma is not blowing Air from any of the vents. I have checked the harness connections to the air controls and hear the compressor engaged when I turn on the AC. I am thinking the relay to the blower motor is out or the blower motor itself is a gone. Can anyone offer some advice if any?
    Thanks!
  2. Jun 10, 2012 at 6:49 AM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    It's the blower motor. Tacomas are bad about that
  3. Jun 10, 2012 at 8:55 AM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Unplug the blower motor and check for power at the plug, if there is no power go back to the resistor. If both have power it's the motor.
  4. Jun 10, 2012 at 9:35 AM
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    Mine did that and luckily it was just the fuse. The fuse looked fine, but I said "what the heck" and changed it. That did the trick. You have extra fuses on the back side of the fuse box top. It's worth a shot.
  5. Jun 10, 2012 at 10:41 AM
    bytor78
    bytor78 [OP] Member
    PreRunner TRD
    Thanks! I will try checking the fuse box and then move on to checking Power to the plug and resistor. I will let you know what I find!
  6. Jun 10, 2012 at 10:41 AM
    bytor78
    bytor78 [OP] Member
    PreRunner TRD
  7. Jun 10, 2012 at 10:51 AM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    Resistor pack is my bet.
  8. Jun 10, 2012 at 11:41 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    resistor? what does it look like?
  9. Jun 10, 2012 at 11:47 AM
    Ryanv
    15 4Runner
    Look at the 2nd sticky
  10. Jun 12, 2012 at 2:58 PM
    bytor78
    bytor78 [OP] Member
    PreRunner TRD
    I have not had a chance to correct the problem, but I gave the motor a whack and voila! What do you know! It started to blow cold air. The fan started slow in the Hi position then gradually increased speed. This leads me to believe the either the connector or resistor is going out? Do you all agree? Or am I missing something?
  11. Jun 12, 2012 at 4:55 PM
    Ryanv
    15 4Runner
    most likely the motor
  12. Jun 13, 2012 at 6:25 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Mine does this from time to time and I can take my hand and bump the blower motor and it will start blowing. I guess the brushes are going bad in my motor. Turn it on and give it a good bump and see if it will start.
  13. Jun 13, 2012 at 6:14 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I guess mine is going to fail on me sometime soon uh? I LOVE WHAT YOU DO FOR ME TOYOTA!
  14. Jul 11, 2012 at 7:11 AM
    bytor78
    bytor78 [OP] Member
    PreRunner TRD
    Well, I gave the blower motor a love tap with the palm of my hand and what do you know! It fired back up and has been working ever since about a month ago. I am going to buy a new motor though and keep it ready for install just in case love tapping doesn't work anymore!
  15. Sep 18, 2012 at 4:18 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    had this problem today, turned on AC and nothing was blowing. turned the knob full blast and still nothing. so i was like whatever, put windows down drove to walmart and when i got back in it was working. so i suppose the fuse/ and or relay was going bad. hopefully nothing worse.
  16. Sep 18, 2012 at 4:32 PM
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Sounds like the blower motor coil could have a dead spot. If this is the case and the motor coil just happens to stop in the right position where this dead spot is, it would occasionally have trouble starting back up and a love tap could move the coil just enough to get it started.
  17. Nov 29, 2016 at 7:10 PM
    haynkanaka
    haynkanaka New Member
    Pre runner 06 tacoma 4dr rgr bed
    I had the same problem blower stopped working, gave it a love tap and working again. i also have this problem the second highest setting for the blower is really soft. any suggestions
  18. Nov 29, 2016 at 7:49 PM
    Taco'09
    Taco'09 Well-Known Member
    Could be the motor as it has a really, really bad history, something like 4 revisions.
    You might also be jarring the connector a little by giving it the tap. Follow the wiring backwards from the motor about 6 inches to its connector. This is where it connects to a large resistor (green on older models).
    Unplug the connector and look at the area where it connects, you should see the 4 terminals. If it looks like it has been hot or burned, there is the trouble. The resistor can also be removedby undoing the two small bolts. The connector's terminals are undersized for the current and make poor contact to boot so it overheats. There is a TSB for this that includes a new resistor and upgraded pigtail. Alternatively this same upgrade kit can be found on ebay or Amazon under the Delco label.
