AC Problems 2016
Discussion in '3rd Gen. Tacomas (2016+)' started by Bmarilyn, Oct 18, 2017.
  1. Oct 18, 2017 at 12:13 PM
    Bmarilyn
    Bmarilyn [OP] New Member
    2016 Tacoma
    The AC switches off while driving. Push the button for it to stay on for 3 seconds. Anyone experienced this?
  2. Oct 18, 2017 at 12:33 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Welcome to TW.
    Not sure what the problem is, do you mean it shuts off by itself after 3 seconds of driving? What temp do you have it set at? Is defrost on?
  3. Oct 20, 2017 at 2:42 PM
    Bmarilyn
    2016 Tacoma
    The a/c will be blowing cold air. Then the AC switch light goes off and the cold air becomes warm. I push the switch and ac stays on for 3 seconds. Goes off and repeat.
  4. Oct 20, 2017 at 2:53 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Have you tried turning the set temp down?
    Edit: Another question, do you have the manual or automatic system?
  5. Oct 21, 2017 at 2:31 PM
    Bmarilyn
    2016 Tacoma
  6. Oct 21, 2017 at 6:53 PM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Sounds like a dealer visit. Good luck and let us know the outcome. Sharing around here helps us all. Sorry couldn't help further, but there seems to be no reason for your problem.
  7. Jun 12, 2019 at 3:56 PM
    Split|Circuit
    Split|Circuit Well-Known Member
    Valley of the Sun
    2017 TRD Off 4x4 DblCab, White, Blk/Org Int
    Bone Stock
    Waiting for the outcome...
  8. Jun 12, 2019 at 3:59 PM
    @T.A.C.O.M.A
    @T.A.C.O.M.A Well-Known Member
    Los Angeles
    I have a different issue.
    When I turn everything off, it continues to blow air. Room temp, but continues to blow. I just close the vents but then it makes the noise of air blowing through closed vents. It’s annoying, but I have been living with it for a year +.
    Anyone else?
  9. Jun 12, 2019 at 4:01 PM
    ryan760
    ryan760 Well-Known Member
    California
    2019 TRD OR, 4x4, Tech, AT, Silver
    Bed mat lol
    Might just be low on refrigerant.
  10. Jun 12, 2019 at 4:11 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Turn it on recirculation to stop the air through the vents.
    @T.A.C.O.M.A and JaCado like this.
  11. Jun 12, 2019 at 4:20 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Or high. High pressure cut out. Take it in.
    ryan760 and JaCado like this.
  12. Jun 12, 2019 at 4:22 PM
    JaCado
    JaCado Water Janitor
    Also check to see if you turned the dial all the way to the left for " max air" that will keep it going as well.
    @T.A.C.O.M.A likes this.
