AC squeals when ac is on. ac blinking light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Abramsan16, Jul 11, 2019.
  1. Jul 11, 2019 at 7:29 PM
    Abramsan16
    Abramsan16 [OP] New Member
    Abram
    2005 Silver Tacoma TRD Sport
    Aftermarket Wheels, Leveled Out
    Two days ago i was sitting in my truck getting cool in 95 degree weather and all of the sudden i hear a squealing sound and smell burning rubber through the ac. the ac light started blinking then turned off. I've read threads that it could be the ac clutch or a bearing thats having issues. Can anyone confirm? I will be posting a video of the sound to the thread later tonight or tomorrow. Thanks!
  2. Jul 11, 2019 at 7:42 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Abramsan16[OP] likes this.
  3. Jul 11, 2019 at 7:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Probably the clutch assembly, but It could also be a seized compressor.
  4. Jul 11, 2019 at 10:03 PM
    Abramsan16
    Abram
    Thanks man.
    Also, i noticed the clutch assembly was pretty deep and hard to reach within the engine bay. Do you know what components you removed to get more space to work on the compressor? Thanks.
  5. Jul 11, 2019 at 10:38 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Crank the wheel all the way to the left and you will see black triangle flap that is held in place by a few clips in the wheel well. Your compressor is behind the forward one. I’m on the fat side and was able to remove and install the compressor by squeezing my body in between. Removing the tire would have been to easy.
  6. Jul 11, 2019 at 10:39 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    https://www.youtube.com/watch?v=rulXlnG2Unk
    Starting after 4:30 he shows how he gets to the compressor through the wheel well area. Should just need to remove the belt and then the clutch. Never removed a compressor clutch but it should just be a bolt and then the clutch sits on a splined shaft... might need some sort of impact to easily loosen it.
  7. Jul 11, 2019 at 11:12 PM
    anthony250f
    Anthony
    San Diego, CA
