ac stopped working and light flashed
Discussion in 'Technical Chat' started by RedBaron, Jul 5, 2013.
  1. Jul 5, 2013 at 9:15 AM
    RedBaron
    RedBaron [OP] New Member
    CT
    08 4cyl 4WD
    While driving the ac light started to flash and ac did not cool. Tried recharging and it would not take one can. Now nothing happens at the ac switch.
    Thanks for replies. Problem is not the relay. Was replaced with a known good one and the a/c still does not work. I suspect the high pressure switch. Does the system have to be evacuated to change that? The system seems to be fully charged.
  2. Jul 5, 2013 at 9:26 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    4Runner, Tundra
    Cut & broke off some stuff.
    Fan and defrost are still working? Just not a/c?
    Had something similar on mine. Push and pull on the fan speed knob. Mine had bad contact on that knob that affected whether ac would come on.
    Pop out the knob panel and just make sure plugged in. I ended up having to bend the metal tab inside to get more pressure for contact.
    Or, check fuses?
  3. Jul 5, 2013 at 9:30 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I had a similar problem recently, and searched around on TW. It seems there is a known issue among Toyotas in general, where the A/C Fan Clutch relay goes out intermittently.
    This is usually remedied by turning the A/C off and back on, but a replacement relay may be necessary.
    Here's some good info. from another thread:
  4. Jul 5, 2013 at 9:38 AM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    I saw this and immediately went looking for your post Ben. Did the relay fix it?
  5. Jul 5, 2013 at 9:40 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I haven't replaced it yet, as it only happened once on out TSF trip. I just pressed the A/C button off, then back on and haven't had a problem since.
    I originally thought the refrigerant was low, but after reading up on it more, I'm leaning towards a bad relay.
  6. Jul 13, 2013 at 5:12 AM
    09GreenSugarTaco
    09GreenSugarTaco Member
    Willis
    Norfolk, VA
    09 PreRunner SR5 green with black MTs
    Lift, MT wheels, Nitto terra grapplers
    I am having an AC issue. The AC always works on full blast but when it's set on another setting it turns on and off on its own. Would this be the relay issue? I had posted on another thread and was told to check the blower fix on this website. Thanks for any help
  7. Jul 13, 2013 at 5:16 AM
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Mine does that if you have a good splashdown in the water. Cycle the A/C switch, fixes it immediately.
  8. Jul 14, 2013 at 7:04 AM
    09GreenSugarTaco
    Willis
    Norfolk, VA
    I cycle through them but usually takes a little while for it to start working. Usually while driving down the highway it will stop and then start back up. It seems to be fine after I drive for a while. It did rain pretty hard a couple weeks ago. Not sure if that has something to do with it. Makes me curious now that you say that.
