AC System Operation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pittsy, Aug 26, 2023.
  1. Aug 26, 2023 at 1:53 PM
    Pittsy
    Pittsy [OP] Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Well, as a few of you know, I've LS Swapped my tacoma, and now it's time for AC. Ive been committed to the idea of just running the AC Compressor clutch on a simple switch and relay, at the risk of completely freezing up my evaporator due to the lack of pressure or temperature sensors. Ive been tossing the idea around to put some of these temp or pressure switches in, but I dont know what pressure or temperature the evap core starts to ice over at.
    Are there any AC geniuses here?
  2. Aug 26, 2023 at 1:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Someone in the GX swap thread said they could possibly make a module for the AC to work in that thread. Maybe see if that guy can help you?
    I’ll see if I can find the post or tag the guy.
    Jimmyh likes this.
  3. Aug 26, 2023 at 1:58 PM
    TnShooter
    Deogee
    STOCK
  4. Aug 26, 2023 at 1:58 PM
    Pittsy
    Davis
    Cave Creek, AZ
    The problem is I dont have any of the pressure sensors anymore. Tricking the AC amplifier into thinking there is RPM and ECT is one thing, but it actually needs system pressure to deactivate that compressor when required.
  5. Aug 26, 2023 at 2:00 PM
    TnShooter
    Deogee
    STOCK
    Then I have no idea.
    I don’t do AC. Or transmission.
    Maybe @Dm93 has an idea.
    He’s the only guy I know on here that does AC work.
  6. Aug 26, 2023 at 2:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    High pressure cutout on the liquid line is typically set around 450 psi.
    Most expansion valve systems use an evaporator temperature sensor/switch because its much more accurate than using a low pressure cutout for freeze-up protection, typically they are set to cut out around 34F and on around 37-40F.
    TnShooter likes this.
  7. Aug 26, 2023 at 3:27 PM
    Pittsy
    Davis
    Cave Creek, AZ
    Does the 2nd gen evap have a temperature switch I'm able to utilize?
  8. Aug 26, 2023 at 4:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There's a thermister on the evaporator but you would need some kind of electronics to use it if your not going to be using the stock A/C Amplifier.
  9. Aug 26, 2023 at 4:22 PM
    Pittsy
    Davis
    Cave Creek, AZ
    I’m using the stock amplifier, but because I don’t have an RPM signal or ECT signal or any of the pressure switches I doubt it’ll engage the compressor. Was planning on keeping it to run the blower motor and servo motors and blend doors, and have a secondary button for the compressor
  10. Sep 5, 2023 at 7:52 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Jimmyh likes this.
  11. Sep 6, 2023 at 9:40 AM
    Pittsy
    Davis
    Cave Creek, AZ
    Thats actually brilliant! Do you have the pinout available for the two connectors going into the AC Amplifier?
  12. Sep 6, 2023 at 10:11 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I can grab it later.
    Pittsy[QUOTED][OP] likes this.
  13. Sep 6, 2023 at 7:41 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Here you go.
    Pittsy[OP] and TnShooter like this.
  14. Sep 7, 2023 at 8:03 AM
    Pittsy
    Davis
    Cave Creek, AZ
    Thank you sir!
