AC Whistle / Mildew
Discussion in '3rd Gen. Tacomas (2016+)' started by bshammer0, Mar 24, 2017.
  1. Mar 24, 2017 at 3:30 PM
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Folks - Anyone had any experience with a whistling sound from the front air vents when running the A/C? I noticed it several weeks ago and it just wasn't a big enough deal for me to be concerned with, but today I had a pretty noticeable musky/mold-like smell when I turned on the A/C - reminiscent of an OLD vehicle (my '17 has 6k miles). Truck is garage kept except for mountain/camping trips a couple of weekends a month. Anyone else experienced this?
    I know it's not earth shattering like some issues but still don't feel like a brand new truck should start to smell moldy esp. when it's hardly ever left in the elements...
  2. Mar 24, 2017 at 3:38 PM
    bshammer0
    Brandon
    Nashville, TN
    Ok, now I feel less crazy. thank you. please post back your results. I'll pay attention to the drips as well - bought mine in November and am only now starting to see warm days occasionally and is likely why I hadn't noticed it until recently.
    CusterFan likes this.
  3. Mar 24, 2017 at 5:55 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Check the incab filter for the airconditioner.
    Bolsillos5624 and bshammer0 [OP] like this.
  4. Mar 25, 2017 at 5:44 AM
    CusterFan
    CusterFan Stewart-Haas Racing
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    @bshammer0 ...... Here is a video on how to replace your cabin filter if you want to check out your filter to see if it is dirty. I threw that plastic shelf away the 1st week I bought my truck. It just limits the things you can carry in there. I also included a Amazon link for the filter if you choose to replace yours with this brand.
    https://www.amazon.com/dp/B001CEJH0...TF8&colid=37S7Q81SMUM6W&coliid=I1WXBBRVU16H5I
    https://www.youtube.com/watch?v=Qpfw-6IOArA
    bshammer0 [OP] likes this.
  5. Mar 25, 2017 at 5:52 AM
    meyergsr
    meyergsr Well-Known Member
    Frederick, MD
    17 Tacoma OR, AC
    It probably wouldn't hurt to check the cabin filter. Maybe it got wet and its the source of the mildew.
    Also you mentioned a whistle noise that maybe the filter clogged or something.
  6. Oct 22, 2017 at 7:26 PM
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    So the factory cabin air filter had the arrow pointing up (airflow) when I pulled it out. But video says point it down.
    Any guidance on air direction? Thanks in advance.
  7. Oct 22, 2017 at 8:04 PM
    TurnLeft
    Gotcha, Thanks!
  8. Oct 23, 2017 at 10:56 AM
    bshammer0
    Brandon
    Nashville, TN
    hadn't touched this thread in awhile... but my truck did drip the condensation this summer but I'll tell you the mildewy / moldy smell in the air system is terrible. I know it sounds silly but to me that's normally been a "non related" sign it's time to trade up to a newer vehicle. In every SUV/truck I've owned it took several years before the slightest hint of biological buildup started to be noticeable. This truck started that as soon as I ran the A/C this year and has only gotten worse. I have kept the air filter clean and change it more frequently than I'm supposed to but this system just doesn't drain the moisture out very well. I even periodically would turn the heat on full blast before shutting off the truck to dry the system out after using AC and still didn't do much.
    I'm just living with it as a "standard characteristic" but I am curious whether there is any "easy" stuff that could be used to spray or something into the air system to actually kill the bacterial buildup that causes that...
    CusterFan and RangerComa like this.
  9. Oct 23, 2017 at 11:42 AM
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Ok youngsters: AC or fresh air smells bad? Turn on the ac, fresh air ,blower at max,Open windows and spray a can of Lysol into the system.
  10. Oct 23, 2017 at 11:48 AM
    venezian
    venezian Well-Known Member
    Los Angeles
    2017 TRD OR 4x4 M/T
    Aren't you supposed to get fresh air in at least every other time you turn on the AC? Mean you turn off the air recycle, let outside air in with windows open to blow all the hot air out, then switch back to reycle air and close windows.. I do this every other day or so to keep from getting that wet and stale smell from coming into the cabin.
  11. Oct 23, 2017 at 12:51 PM
    TurnLeft
    This was from your current condenser?? So does Frigi Fresh just mask this buildup or kill off the bacteria?
    Back to your condenser - I'm sure you cleaned it up, but how often would this maintained be required? I got that mildew smell after 10k miles.
  12. Oct 24, 2017 at 11:57 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Paint Protection, Borla S-Type Catback Exhaust ME-SO Customs Gasshole ME-SO Customs Total Tails Stage 1 ME-SO Customs Ultimate LED Turn Signals V4 HELLA Supertones OVTuned 2.0 2LO Mod 16x8 0mm Enkei RPT1 Wheels in Titanium Gold Diode Dynamics SS3 Pro Foglights HPS Intake Hose
    Frigi Fresh is great! However, I use the Subaru climate control cleaner kit.
    http://bit.ly/2gE9nHY
    It works really well. And it smells better than Frigi Fresh.
