ACA HID install Need help!
Discussion in 'Lighting' started by Tulku, Jul 1, 2010.
  1. Jul 1, 2010 at 8:21 PM
    Tulku
    Tulku [OP] Active Member
    Joshua
    Los Angeles
    Gen-1 Debadged Prerunner
    Custom Grill by Racemeshgrills.com Turn signal mod Deck plate mod Bilstein 5100's Dyna-mat / custom stereo
    I've been working on installing these ACA HIDs in my 1st Gen Tacoma for 4 days now and I cant get them to trigger on using the light switch.
    Right now I'm thinking it must be an issue with the stock toyota H4 plug or something like a diode I'm missing.
    I know they work because I can bypass the relays and they fire right up.
    does anyone here have experience installing HIDs in an 01-04 Tacoma?
    1) I know they work
    2) I don't have DRLs
    3) I discovered the ballast plugs were reversed
    Aside from the obvious, is there some well known issue people have when installing these lights in a tacoma?
  2. Jul 1, 2010 at 8:23 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    grounds...i tore my shit apart and found up i grounded my setup to plastic.....don't judge
  3. Jul 1, 2010 at 9:56 PM
    Tulku
    Joshua
    Los Angeles
    well after reading up on HIDplanet
    Now I think my wiring harness is set up for a positive switched H4 plug and I have a ground switched H4...
    anyone here know how I should go about fixing this?
  4. Jul 2, 2010 at 5:50 PM
    Tulku
    Joshua
    Los Angeles
    After messing with the H4 plug today I was able to get the light switch to trigger the lights on,
    but only the low beam, (apparently my H4 low is on the side of the plug instead of the middle)
    if I switch on the brights while the low is still connected it shorts out or something.
    Another thing I discovered today,
    when my lights are on I have no ground continuity at any of the three points of contact on the H4 plug,
    is there some kind of anomaly with my truck?
    Come on, no one has had this problem?!
  5. Jul 2, 2010 at 6:03 PM
    CopDoctor
    08 335i
    did you ever have to tap into a hot wire for power? if so you probably tapped into a wire that is only hot when the low beams are on...just a guess
  6. Jul 3, 2010 at 3:05 PM
    Tulku
    Joshua
    Los Angeles
    Here is the diagram of the positive switched wiring harness that came with the ACA's
    Can someone help me design a Ground switched wiring harness that will work within ACA's parameters based on this schematic?
    I have a larger pic if you PM me
    Thanks! -J
