********* Access cab kit screws?
Discussion in 'Audio & Video' started by voltron75, May 23, 2008.
  1. May 23, 2008 at 2:56 PM
    voltron75
    voltron75 [OP] Member
    SoCal
    08 PreRunner TRD Access Cab
    I was about to order the access cab kit f6x9 r6.5 from *********. I've read on some threads that they package the incorrect sized screws/bolts for the rear mounts. Does anyone know if they corrected that yet? Has anyone order a kit from them recently?
  2. May 23, 2008 at 3:27 PM
    ChibbMD
    ChibbMD Well-Known Member
    Dallas, TX
    08 PreRunner Double Cab
    Even better question is simply what size bolts and washers could you buy from the hardware store? Anyone know? I'm about to install new speakers and I'm going to find out one way or the other. Just thought it would be nice to get it right the first time. Thanks.
  3. May 23, 2008 at 3:38 PM
    voltron75
    SoCal
    My thoughts exactly, I'm probably still going to buy the kit, but if it's known that they still send the wrong bolts, then I can go to homedepot and get the correct ones beforehand, so I don't have to make a run with the door panels off.
  4. May 23, 2008 at 4:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Best thing to do would be to take one of the existing screws out and bring it to an Ace Hardware (or equivelant) and match it there. I have done this in the past with good results. :)
