Access Cab w/ I4 (Possible?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PhoenixCadet, Jun 15, 2008.
  1. Jun 15, 2008 at 1:34 PM
    PhoenixCadet
    PhoenixCadet [OP] Well-Known Member
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    I checked a while back on the build-it-yourself part of the Toyota website, and for the '08 Tacoma Access Cab, I was able to successfully have an I4 with it.
    I can't do that now. The only option for the Access Cab is the V-6.
    Did they change something? Or can you still get an I4 with an Access Cab?
  2. Jun 15, 2008 at 4:30 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Put in another Zip Code, and try again.
  3. Jun 15, 2008 at 6:13 PM
    PhoenixCadet
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    Got it. Thanks.
    Now, another question. I tried the same for this (changing the zip code, and it didn't work), but... Is there any way you could get an I4 (Auto), Access Cab with the PreRunner drivetype?
    Does that depend on the zip code, as well? Or is that not possible?
  4. Jun 15, 2008 at 6:15 PM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    I know it was in 07. Try another zip.... Try a texas one. Try 75247
  5. Jun 15, 2008 at 8:59 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    No 2.7 with automatic in the current 4WD/PreRunner; just the 5 lug chassis.
  6. Jun 15, 2008 at 9:06 PM
    PhoenixCadet
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    The reason why I prefer the PreRunner is because it's (to my knowledge) a bit more raised than the regular version.
    This might seem like an elementary question, but - how would one go about getting a truck raised a bit? Is that something you do before it comes off the lot?
    I'm not talking about much. This would be great:
    (I ask this because - from what I've seen, Tacos that aren't PreRunners are generally lower than this.)
  7. Jun 15, 2008 at 9:11 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    you can do it in the 70005 zip code but no automatics.
