Access roll up cover work with deck rail system?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metalhead77, Dec 31, 2011.
  1. Dec 31, 2011 at 2:05 PM
    Metalhead77
    Metalhead77 [OP] Well-Known Member
    CA central coast
    2012 DC LB sport upgrade 4x4
    Access bed cover-bed mat-Westin polished stainless steel steps-front skid plate BFG Rugged Terrain tires
    Just picked up our '12 DC LB sport last night and I want to get an Access roll up cover for it.
    Does anyone have one of these on your taco and does it interfere at all with the deck rail system?
    I need to move my tie downs almost every time I use the truck and need to be able to adjust them with no problems.
    Thanks in advance.
  2. Dec 31, 2011 at 2:07 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    It does not. You have to take rail system off and the deck goes underneath the rail... then reattach rail. I like mine.
  3. Dec 31, 2011 at 2:48 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Works with the regular profile ones, not the low profile (i.e. Laredo) versions.
    One difference, the tie downs cannot be rotated and removed, only slid out the rear of the rails. Keep that in mind with the front rail, meaning if there are tie downs up there prior to installation they're kinda permanent until the cover comes off if I understand correctly.
  4. Dec 31, 2011 at 6:46 PM
    TJ Asher
    TJ Asher Well-Known Member
    TJ
    Minneapolis
    '10 Virgin
    No problems getting the tie downs in or out on any of the rails.
    The access cover rails go behind the side rails. It's a great design and the holes lined up perfectly. The torx bolts can be a bitch to get out but they get replaced by hex bolts supplied by Access.
