Accessory Meter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ochoa104, May 16, 2008.
  1. May 16, 2008 at 6:30 PM
    ochoa104
    ochoa104 [OP] Member
    Hey everybody
    A week ago I started having trouble with the accessory meter in my 06 Tacoma. Two days ago the meter went out. I looked to see if it was a fuse and did not find anything wrong. Does anyone know how to fix my accessory meter?
  2. May 17, 2008 at 2:50 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Yes, it is a common failure but generally an easy fix. You need to remove the meter console from the roof. Remove the single screw and grasp the sides and pull down firmly. Don't pull too far as there are wiring connectors to undo. Once you get the assy. out, remove the meter circuit board.
    What has happened is there are large flat gray/black resistors on that circuit board that have come unsoldered to the PCB. If you can't solder, take the circuit board into a TV repair place and have them solder the resistors for you. Have them cake on the solder at the ends of those resistors so this will not happen again. Once done plug the circuit board back up to verify it works and installation is now the reverse of removal. BTW, the factory charges around $900 for that part! Thankfully most say this takes care of the dead compass/temp. gauge situation. :)
    RA77 likes this.
  3. Nov 4, 2008 at 2:43 PM
    amastalerz
    amastalerz New Member
    trd
    I removed the screw but it looks like there are tabs after the sunglass holder above the felt roof. Is there a trick to this?
  4. Nov 4, 2008 at 2:59 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    There are "fixed" tabs in the front by the sunglasses holder. DO NOT PULL DOWN FROM HERE! You'll rip the ceiling! Almost happened to me... As 45longcolt said, pull down firmly from either the sides (towards the front) or the front. There are two tabs that have metal clips on them just above the temp/compass gauge. When I pulled mine off, these metal clips came off of their plastic tab mount and made a loud clanging - I thought I broke it! But, these metal clips will just go right back on the plastic tab for you to push back into the ceiling.
    I hope this made sense (between the front, back, top, metal clips, plastic tabs, etc...) :)
    Let me know if you have anymore questions.
  5. Oct 27, 2009 at 8:55 PM
    kaayvang
    kaayvang New Member
    Kaay
    05 Tacoma TRD Sport
    Thanks alot!!! I was able to fix my Accessory Meter.
  6. Aug 18, 2010 at 4:44 PM
    Tacomatruck
    Tacomatruck New Member
    Joe
    Newmarket Canada
    07 Tacoma Dbl Cab
    Your description on how to repair the Accessory Meter was perfect. I joined the forum to say thank you.
    Joe
  7. Sep 21, 2010 at 2:06 PM
    shineybuffalo
    shineybuffalo New Member
    Roy
    Va. Beach
    05 Tacoma
    I will be trying to repair the accessory meter on my 05 Tacoma in the next couple of days. I will post a reply to how it goes for me. I do want to thank everyone for posting info on how to get to this part.
  8. Sep 21, 2010 at 3:46 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    Im dumb wtf is an accessory meter and why is it broke
    winkel and Marc70 like this.
  9. Sep 21, 2010 at 3:58 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'm presuming the temperature gauge/compass... but I was also confused by the term.
  10. Sep 21, 2010 at 4:33 PM
    evile
    Orlando, Fl
    AH why dont we just call it the Compass/outside temp display because thats what it really is. Im sitting here drinking my rum going WTF is an accessory meter.
    BTW mine went out last year. I got by with the Fonz technique.. smack it and it works for a few months then got it replaced under my ESP warranty
    Marc70 likes this.
  11. Oct 18, 2010 at 5:43 PM
    shineybuffalo
    Roy
    Va. Beach
    05 Tacoma
    Itook my accessory meter out last week and one 510 resistor was missing completely from the Board. The display also had a burned spot so I went to my local dealer and bought a new accessory meter (which they had in stock) and installed it and it works fine. The compass only required that I drive in a circle and it was set and working fine. I paid $118 for the part.
  12. Oct 18, 2010 at 5:48 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    That burn in the corner was normal. All you had to do is solder the 510 connector edges and it will work fine.
  13. Dec 24, 2010 at 12:08 PM
    jleo9625
    jleo9625 New Member
    corona
    toyoto PreRunner
    Hey thanks everyone,
    This worked for me as well. I have a 2007 and had the same issue. I became very clear when i Found it was labled 510 so i sodered them and now it works great.
    Thanks again
  14. Dec 24, 2010 at 3:06 PM
    jgray
    jgray Well-Known Member
    josh
    boyds,md
    05 Ext.cab "murder was the case"
    Aero turbine sidepipe 3" pipe Murdered out 3"revtek leveling kit 33's
    I did the solder shit but now my meter doesn't read the temp.lol
  15. Dec 24, 2010 at 3:22 PM
    JKD
    JKD Well-Known Member
    Toyota calls it the accessory meter.
    I've been trying to get the word out on that (with regards to the "burn" mark), hence my sig. Too many people assume it's bad!
  16. Jan 8, 2011 at 3:24 PM
    gforce
    gforce New Member
    Gary
    San Diego
    07 Taco DC, LB 4X4 TRD SPT
    K&N CAI
    Just as explained in the earlier posts the burn mark is normal, I thought the AM was burned out until I read the thread. Once I found the 510 connectors it took me a couple of minutes to see both were cracked because they are so small, soldered them both and works like a charm! I'm guessing cold weather is what makes the solder areas to fail, because that is when mine started acting up. Thanks for the thread just saved me some serious cash!
  17. Jan 11, 2011 at 12:45 PM
    Orangeblood
    Orangeblood New Member
    Brandon, MS
    07 4x4 Silver Double Cab
    The fix for the meter was spot on! Only advice I'd offer is that the solder gun I used had a large tip. The 510 resistors are very small. I needed to use a small solder tip.
    Thanks for the help guys. It really did take 10 minutes or less!
  18. Jan 14, 2011 at 5:29 PM
    Summit1
    Summit1 New Member
    2006 Tacoma 4WD
    I followed the soldering instructions but my accessory meter still not working...any suggestions?
  19. Jan 15, 2011 at 12:05 PM
    JKD
    Is the accessory meter getting power?
    If so, then I'd check the connections, then re-check your repair.
  20. Jan 28, 2011 at 3:35 PM
    itzmejaybe
    itzmejaybe New Member
    BJ
    Harnett County NC
    06 Tacoma 4x4
    265/70/17 tires so far. Also a front end hitch receiver.
    Had the same problem with the tabs that came off and now trying to get the gauge off the main unit. Star screws is what it looks like to take out and still wonderin about the soldering deal. Any help would help!!
