Accessory Power Clean Up
Discussion in 'Technical Chat' started by apbright, Nov 23, 2021.
  1. Nov 23, 2021 at 10:25 AM
    apbright
    apbright [OP] Well-Known Member
    Aaron
    2007 Silver Tacoma Base
    Is there anyway to clean up all the power leads going to the battery? I have a lightbar, amp, and more to come and I was not sure if there was a way to clean up multiple leads going to the battery or not.
  2. Nov 23, 2021 at 10:36 AM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    TomTwo and vtown like this.
  3. Nov 23, 2021 at 12:06 PM
    apbright
    Aaron
    To be frank, the panel option is a little over my head, I've just been doing simple things. The terminal breakout connectors seem quite cool and what I want, is there any preferred brand/price range? I do not want to cheap out but they are on Amazon for like $12
  4. Nov 23, 2021 at 12:11 PM
    apbright
    Aaron
  5. Nov 23, 2021 at 1:20 PM
    MuddySquirrel
    Will
    Phoenix
    I've no experience with those particular ones. Personally I'd prefer a bolt to the quick release handle and would go for something like https://www.amazon.com/dp/B01LLWKXV6/
    or https://www.amazon.com/dp/B096FHWHCY/
    In practice I run an aux fuse panel.
    How many devices do you plan on connecting, and does your battery have lug or screw connectors?
    I'd take your planned number of connections (n), then look for a terminal with between (n/2 +2) and (n+3) connections. You can usually get two connectors on a terminal, need a spare for the stock connection, and I'd add two slots to grow.
    If you're going to use more than 6 connections, a block will make your life easier in the long run (and way less spaghetti under the hood). They can look a little intimidating, but are fairly straightforward once you get into them. TW's big enough that there's likely someone local to you willing to help.
    Regardless of the breakout type, remember to appropriately size and fuse all your wiring.
  6. Nov 23, 2021 at 9:17 PM
    apbright
    Aaron
    Okay cool thanks! I appreciate the help. Am I crazy for wanting to replace the battery cables all together and get new ones? Maybe a little longer ones as well? Would this be difficult to do; sorry I am new to DIY whenever it comes to my own truck.
  7. Nov 23, 2021 at 9:59 PM
    MuddySquirrel
    Will
    Phoenix
    Eh, it's a truck forum; wouldn't break the top 100 for craziest mods.
    What do you hope to gain from replacing them? It does allow for additional charging efficiency or could be required if your cables are corroded/damaged... but if your system is running fine you likely won't notice much difference.
    Either way, it's your money and time: here's an example write-up covering the battery cables and then some.
    https://www.tacomaworld.com/threads...lights-hood-lights-aux-panel-and-more.712981/
    One caveat- don't cheap out and crimp wires with pliers. Hydraulic swager or one of these https://smile.amazon.com/Mofeez-Hammer-Lug-Crimper-Tool/dp/B07X2WS3L4/ for the big stuff, crimping tool for the little stuff.
