Actual Owners - Report on the Projector Headlights!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KB Voodoo, Sep 17, 2015.
  1. Oct 1, 2015 at 12:23 PM
    #41
    atrouth
    atrouth Well-Known Member
    Anthony
    2016 MGM Tacoma TRD Sport DCLB 4x4
    Debating if I want to cough up the money for Philips LMZ bulbs in my fog lights or just go with some regular CREE ones and save a hundred bones. Might throw my HID kit in there and just get new bulbs for that, ballasts are not even a year old
  2. Oct 1, 2015 at 12:29 PM
    #42
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    They do project a lot more than stock bulbs. The light is much more crisp on the road and you can actually see whats illuminated where as the stock bulbs kinda just give off a low glow on the road.
  3. Oct 1, 2015 at 12:57 PM
    #43
    atrouth
    Anthony
    Only thing I am worried about with the LMZ is if I will have enough clearance for the bulbs. I dont see why I wouldnt but that was one thing I forgot to check on the V6 they had at the dealership. Otherwise I definitely like the ability for LEDs to turn on with no warm up period. Especially considering the lights on the truck will be auto
  4. Oct 1, 2015 at 1:27 PM
    #44
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    I think the lows are H9 and highs are H11. I only ordered 1 set of VLED because there's only about 1.5 to 2 in clearance behind the low beams. If the fit then I will get another set for the highs. BTW the daytime Running Lights are a nice upgrade from gen2.
    radchris88 likes this.
  5. Oct 1, 2015 at 1:30 PM
    #45
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    Hey Sam,
    You are doing exactly what I am going to do to my truck once it arrives at the end of the month, thanks for break'in trail!
  6. Oct 1, 2015 at 1:31 PM
    #46
    atrouth
    Anthony
    Sam is the washer fluid reservoir causing the clearance issue on the passenger side? If I recall the battery is the only other obstacle on the drivers side. It looks like since the fan vents out the side of the LMZ lights it "should" fit. I'm assuming you ordered the LMZ ones from VLED? Did they give you a delivery date? They're back ordered til the end of the month for H11
  7. Oct 1, 2015 at 1:38 PM
    #47
    atrouth
    Anthony
    So for people with the TRD models and the wide angle fog lights it appears the same bulbs are used in the fog lights as the headlights
  8. Oct 1, 2015 at 1:46 PM
    #48
    DRJ1014
    CA
    Can someone post a picture of under the hood on each side of the headlights, also while the lights are on, do the LED DRL stay on?
  9. Oct 1, 2015 at 1:48 PM
    #49
    atrouth
    Anthony
    I believe so, I think the DRL just dim when the lights are on but I could be wrong
  10. Oct 1, 2015 at 4:19 PM
    #50
    Sam B
    Samuel
    Poway, Ca.
    none
    Actually its the frame. Walled steel for the engine compartment almost is smack in the middle of the low beam bulb. About 1.5 to 2" clearance. Looking at the light specs it is going to be close. Yes, the LMZ's and they said backorder till the 5th of Oct was my last update. They have the various plates to make them H9's or H11's. The issue is the fan unit on the back. Most of the better LED's have the fan. Some people thing thats just one more part to go bad but the lower end bulbs are the single assy without the converter and fans.
    8102 likes this.
  11. Oct 1, 2015 at 4:20 PM
    #51
    Sam B
    Samuel
    Poway, Ca.
    none
    Yes the DRL's are on when the headlights are on also.
  12. Oct 1, 2015 at 4:22 PM
    #52
    atrouth
    Anthony
    Sheet. Is that the issue for both sides? I hope they fit, seems like a high quality product. Not to mention 4x (essentially 16 diodes) LMZ LEDs per bulb should be super bright
  13. Oct 1, 2015 at 4:25 PM
    #53
    Sam B
    Samuel
    Poway, Ca.
    none
    Yup both sides, I looked before ordering and with the price, I only ordered 1 set. The high beams dont have the issue. Easy access.
  14. Oct 1, 2015 at 7:23 PM
    #54
    atrouth
    Anthony
    Curious to see how it works out for you. Much more interested in these new LED over the existing HID system I've been using
  15. Oct 1, 2015 at 7:28 PM
    #55
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Make sure there is enough clearance behind your headlights to not only install your VLED bulbs, but to adjust the collars. Installing them in my truck (Yes I know not a 3rd gen) and adjusting the depth and rotation was insanely hard.
    Sam B likes this.
  16. Oct 1, 2015 at 7:29 PM
    #56
    atrouth
    Anthony
    Did you have clearance issues too?
  17. Oct 1, 2015 at 7:48 PM
    #57
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    On my 2011 Tacoma. Yes absolutely. Guys wanting these for the 3rd gen, I would ensure you have solid three inches behind your headlights in the engine compartment to install these. The cooling fans are pretty big so that, along with your hand in there adjusting doesn't leave a lot of room.
  18. Oct 1, 2015 at 7:51 PM
    #58
    atrouth
    Anthony
    Massive engine bay with lots of open room elsewhere and they cram the lights in there Makes absolutely no sense. I can understand my Honda Civic being cramped under the hood but a Tacoma?
  19. Oct 2, 2015 at 2:05 PM
    #59
    atrouth
    Anthony
    Sam are you able to measure the clearance behind the headlights or take a picture? My thought is as long as the bulb clears once installed then it should be fine. Theoretically they should outlast the truck
  20. Oct 2, 2015 at 5:14 PM
    #60
    Sam B
    Samuel
    Poway, Ca.
    none
    I'll try to get pics when I get home. Been a loooong day at work so far!
