Add intermittent wipers to 2011 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scmurphy64, Jun 12, 2011.
  1. Jun 12, 2011 at 3:53 PM
    scmurphy64
    scmurphy64 [OP] New Member
    Murph
    MA
    2001 PreRunner 4x4 V6 Man
    Hitch and bed mat so far
    I have a base 2011 Tacoma, access cab, 4x4, V6, manual transmission, and the two speed wipers. I have read other postings regarding the addition of intermittent wipers, and the newest model in the postings was 2009. A number of postings listed specific part numbers to order from both Toyota and www.1sttoyotaparts.com.
    Does anyone know if part number 84652-04141 from www.1sttoyotaparts.com, or will this Toyota part number 84652-02610 will work on my 2011 Tacoma, or is there a different part number I should be using?
  2. Jun 12, 2011 at 9:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Late model year Tacoma changes:
    2009>2010: New cupholder lining.
    2010>2011: New grille. New gauge faces.
  3. Jun 13, 2011 at 2:33 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    in another thread someone said that the older switches work in reverse.
  4. Jun 13, 2011 at 4:34 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
  5. Jun 13, 2011 at 9:15 AM
    scmurphy64
    Murph
    MA
    Thanks for the confirmation
  6. Feb 4, 2013 at 2:52 PM
    pat aumiller
    pat aumiller Member
    pat
    dry run
    tacoma
    i also have a 2011 base model tacoma without intermitten wipers and would like to add them.i talked to a toyota tech and he said i would have to add a timer also...any truth to this?
