Added Auxiliary Power Outlet
Discussion in 'Audio & Video' started by falco, Feb 21, 2008.
  1. Feb 21, 2008 at 3:59 PM
    falco
    falco [OP] Member
    I needed an extra power outlet, so I tapped into an extra line found under the cup holder. The cup holder removes by lifting straight up. I cut the Blue Wire with a Black stripe (this goes to the rear AC 400 Watt plug, I have an SR5 = no plug). I added a standard female 12v plug to the wire and grounded to an exposed piece of metal. Hope this helps someone.
  2. Feb 21, 2008 at 5:21 PM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
    Using this connection is the power outlet hot all the time or only with the key in the acc or on positions?
  3. Feb 21, 2008 at 5:37 PM
    falco
    falco [OP] Member
    Nope, it only works when the key is switched to ON. If you know a way to change this, let me know...
  4. Feb 21, 2008 at 7:15 PM
    marvin02
    I did and I wondered whether the one you did would provide a constant on outlet. Thanks for the info.
  5. Feb 21, 2008 at 7:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe this should be added to the cheap/free mods thread and stickied??!!??!!??
  6. Nov 14, 2012 at 11:26 AM
    WYOTAC
    WYOTAC Well-Known Member
    Joel
    Santa Barbara
    06 AC TRD OffRoad Desert Sand
    ICON 2.5 with JBA UCA, OME Dakar
    sorry to revive a dead thread but, I just did this so I could power my Sirius radio with the wires tucked away and it worked wonderfully sitting in the driveway. Next day I go out to run some errands and the power to my radio kept cutting out. After about 10 minutes of driving and getting frustrated at the choppy radio I pinned it to the clutch. The power to the outlet was only lost if the clutch was in for a prolonged amount of time (starting out in 1st) and not lost on quicker shifts (2-6). Anyone have any idea what the deal is. I can't even imagine how these things are connected.
