Adding a Front Header Deck Bed Rail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The_Devil, Oct 22, 2018.
  1. Oct 22, 2018 at 10:38 PM
    The_Devil
    The_Devil [OP] Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I have a 2018 Off-road DCSB
    I have the two side rails but wanted to add the front rail.
    Has anyone added this, and if so, how did you do it, what hardware etc.
    Also, is this just not an option on 2018? I saw it on other Tacos
  2. Oct 22, 2018 at 10:40 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They did away with them starting in 2016 so just grab one for a 2nd Gen, I kept the one from my old 2015 and it bolts right up.
  3. Oct 22, 2018 at 10:42 PM
    The_Devil
    E
    Do you remember if you had to drill through the bed cover? They go for like $50 to $70 and say to use existing bolts, but I don't remember seeing exposed bolts on mine. I may have to see
  4. Oct 22, 2018 at 10:43 PM
    shakerhood
    Southern Ohio
    There was no drilling required as the threaded holes are already there, if you have a Tonneau Cover then I don't think it will work.
  5. Oct 22, 2018 at 10:47 PM
    shakerhood
    Southern Ohio
  6. Oct 22, 2018 at 10:50 PM
    The_Devil
    E
    shakerhood[QUOTED] likes this.
  7. Oct 22, 2018 at 11:02 PM
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    I added one, easy to do.
  8. Oct 23, 2018 at 3:10 PM
    DRansom
    DRansom Well-Known Member
    Newark, CA
    2018 Silver Tacoma TRD Sport 4 X 2
    Are you folks referring to the bolts that hold the front of the bed liner in? I'm looking to put a header track on, and am not sure the dealer will do it. The torx bolt heads I see match up with the holes in the rail?
    Just1n likes this.
  9. Oct 23, 2018 at 3:17 PM
    Clark.W.Griswold
    Clark.W.Griswold Well-Known Member
    Sparky
    2024 Ford Ranger Raptor
    Those are the bolts you want. I added one to my '18. It is now my bike rack!
    Chasespeed likes this.
  10. Oct 23, 2018 at 3:20 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    That's not a bedliner. That is the bed of the truck. It's made from composite, no steel under there.
    The_Devil[OP] likes this.
  11. Oct 23, 2018 at 3:40 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    This does work with factory tonneau cover. I am not sure about aftermarket.
  12. Oct 23, 2018 at 4:17 PM
    DRansom
    Newark, CA
    Thanks. Then when I take out the bolts the holes will still be aligned. Just ordered those parts. I'll just have to figure out how the bed extender attaches. Might be time to use the discount coupon the dealer sent me.
  13. Apr 22, 2019 at 5:09 PM
    FitzTaco84
    FitzTaco84 Well-Known Member
    USA
    2018 DCSB TRD OffRoad 4x4
    I have the Rugged cover. It works. The install literally took me 5 minutes with an impact driver. Five bolts. No drilling. Just remove the old torx bolts. Then install the rail.
  14. Apr 22, 2019 at 5:20 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Can't you just park next to a 2nd gen late at night.....
