Adding a locker, worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoachTaco, Nov 20, 2017.
  1. Nov 21, 2017 at 5:48 PM
    #41
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  2. Nov 21, 2017 at 9:01 PM
    #42
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Dual ARB’s and 4.88s. Hopefully someone finds an ARB Black Friday sale.
  3. Nov 22, 2017 at 11:53 AM
    #43
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    8.4 is 2 pinion.
  4. Nov 22, 2017 at 12:52 PM
    #44
    36tacundra
    36tacundra Well-Known Member
    my bad I got the first mixed with the last.
  5. Nov 22, 2017 at 9:38 PM
    #45
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Cruiser brothers is running a Black Friday/cyber Monday sale on lockers. Better get the Harrop!
  6. Nov 23, 2017 at 7:23 PM
    #46
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    $100 off which gets it down to $1295.
    Info straight off their website:
    Includes - ELocker, wiring harness, rocker switch and instructions. Does not include install kit (carrier bearings/gasket)
  7. Nov 24, 2017 at 11:13 AM
    #47
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Can a Tundra LSD be installed, and be compatible to an E-Locker equipped Taco rear? I have the E-Locker, used it maybe three times, but an LSD for street use, is sure intriguing!
  8. Nov 24, 2017 at 1:59 PM
    #48
    eon_blue
    Azusa, CA
    Can't have both (locker and mechanical LSD) in one differential.
    The Driver[QUOTED] and boostedka like this.
  9. Nov 24, 2017 at 5:37 PM
    #49
    HighLux4x4
    HighLux4x4 Well-Known Member
    Auburn gear makes an elocker that is also a limited slip when unlocked. I think it is only for Dana, Ford, and GM axles.
    I found quite a bit of situations offroad where open is better. So I think the ARB or a eaton/harrop will still be more popular.
    Taka The Tacoma likes this.
  10. Nov 24, 2017 at 5:52 PM
    #50
    devinzz1
    devin
    2023 aclb trd or mt
    what do you know... its nicely priced too.
  11. Nov 24, 2017 at 10:51 PM
    #51
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    Hi CoachTaco--
    A great addition to the Prerunner. Harrops are my choice for my own personnel 01 Tacoma. I will soon have them front and rear.
    https://www.yotatech.com/forums/f15...-2001-tacoma-283930/index17.html#post52366192
    It's 1395 thru https://www.cruiserbrothers.com/product/harrop-elocker-a13457/ and knock 100 off if you make your decision before November runs out. Roughly 200 for my labor and roughly 55 for fedex ground to CA and BAM!!!! you can have an awesome selectable elocker ;)
    http://gearinstalls.com
    ZUK aka Ken
    CoachTaco[QUOTED][OP] likes this.
  12. Nov 25, 2017 at 7:48 AM
    #52
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Anyone used a Powertrax Lockright in a '02 Tacoma- 8.4 Rear (Open) NonTRD- diff. w/4wd ? 4cyl.-Auto- Pros, .Cons, good, bad.?? -Daily driver - 98% Street . Thanks
  13. Nov 25, 2017 at 8:03 AM
    #53
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    A Spartan is easier to install than a LR as info.
    They both will pop and bang some when you are making tight turns in parking lots. Having an auto makes it less noticeable than if you had a manual since it opens up when you are coasting with no load on the drivetrain. I DD’ed one for a bunch of miles and was totally fine with it.
  14. Nov 25, 2017 at 8:05 AM
    #54
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    How do I find out if I have the 8.25 diff?
  15. Nov 25, 2017 at 8:07 AM
    #55
    Keep on Truckin'
    Jarvis
    Indiana
    Snowy-Thanks for the info- Spartan doesn't make a locker to fit my '02 rear diff. so I'm pretty much having to use the Powertrax Lockright unit.
  16. Nov 25, 2017 at 8:11 AM
    #56
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I’ll be damned. Never knew Spartan didn’t make one for the 8.4. I had one in my 8” and I have one in my 9.5” now.
    I don’t think the LR is weaker or anything like that, just a little trickier to install with the pins.
  17. Nov 25, 2017 at 8:49 AM
    #57
    Keep on Truckin'
    Jarvis
    Indiana
    Spartan has one for the '90's Tacoma's (8") but Not the 8.4" NON trd w/ 30 splines - Same for Grizzly, Aussie , etc,. -Only one I've been able to find is the PT Lockright
  18. Nov 25, 2017 at 11:00 AM
    #58
    ZUK
    Ken
    Chandler AZ
    Some people call it the 8.25....some the 8.4....some call it the T100 diff. It's all the same but 8.4 is the most common. If your 04 Taco does not have the elocker option then you have the 8.4 diff....a darn good diff....but with limited cheap locker options. ZUK
    ripdawwg likes this.
  19. Nov 25, 2017 at 11:07 AM
    #59
    devinzz1
    devin
    2023 aclb trd or mt
    powertrax no-slip is a much better option for a daily.
    Matic likes this.
  20. Nov 25, 2017 at 11:16 AM
    #60
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I did Eaton LSD, then 4x4 conversion. Very capable. Now, I’m considering a front eLocker.
