Adding a locker, worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoachTaco, Nov 20, 2017.
  1. Nov 25, 2017 at 11:38 AM
    #61
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I disagree with you, I had one of them too and it decided to grenade going down the highway. Took out the R&P and the transmission when it locked up. ECGS does not advise people to put them in either.
  2. Nov 25, 2017 at 11:40 AM
    #62
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Thank you, and thank you for not making fun of what most have feeled like a stupid question. But since the E-locker is electronic in nature, as opposed to an LSD which is hydraulic in nature, I thought it was worth asking.
  3. Nov 25, 2017 at 12:02 PM
    #63
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I've been running a powertrax no slip for 7.5 years and have had 0 problems. I also know a few other running them with zero problems. If it grenaded then it was due to an installation error.
    I've installed 3 of them including my own and it's held up great.
    Lockers just don't explode for no reason. Eaton would be out of business.
    Smalltoytacoma55 and devinzz1 like this.
  4. Nov 25, 2017 at 12:05 PM
    #64
    Matic
    Tricky Dick
    Easley, SC
    And btw....there is a company doing lsd/full locker at the push of a button. The name escapes me, but it does exist.
  5. Nov 25, 2017 at 12:24 PM
    #65
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Well what’s better? My last truck had no E-Locker my new one does. I was pretty happy that the new one has done just in case.
  6. Nov 25, 2017 at 12:26 PM
    #66
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    the 8.4 is stronger due too a trussed bearing cap and bigger pinion bearings.
  7. Nov 25, 2017 at 12:27 PM
    #67
    Shortman5
    Supercharged TRD
    Well damn. I’m not taking my new one off-road anyway. It’s too clean for that and it’s a DD. I can’t wsit until I get the cash for a trail rig.
  8. Nov 25, 2017 at 12:31 PM
    #68
    devinzz1
    devin
    2023 aclb trd or mt
    my no-slip has been flawless for almost 4 years. currently running 35" tires with it.
    Matic[QUOTED] likes this.
  9. Nov 25, 2017 at 1:27 PM
    #69
    Matic
    Tricky Dick
    Easley, SC
    Love mine. I live in south carolina but travel to indiana for the holidays and run into severe snow quite frequently.
    Not ideal for a full time locker. You simply have to "relearn" how to drive in that situation. I drove 7 hrs from northern Indiana to Tenn in 7-10 inches of snow a few years ago.
    It was white knuckle the entire time. But 600 lbs of sand, 20 lbs of air in the tires, patience and a steady throttle and I made it.
    I wouldn't recommend it if you live in colder climates where it snows often.
    Edit: I'm guessing you get a lot of snow in Newfoundland?
  10. Nov 25, 2017 at 1:45 PM
    #70
    devinzz1
    devin
    2023 aclb trd or mt
    i drive with snow on the road half of the year. maybe im just used to it but it doesnt affect me at all. i dont even notice it there. its really no worse. maybe even better than a clutch type lsd in snow. a clutch lsd will stay "locked" because there isnt enough torque to make it slip. as soon as you let off the gas with this it seems to unlock nicely.
  11. Nov 27, 2017 at 10:52 AM
    #71
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    Nothing tricky! You may be confusing the Lockright with the Powertrax unit..
    I've used the Lockright in Fords... Great unit.. Ratchets on corners... No big deal... Its a conversation maker!
    One thing though, it increases your overall backlash of the driveshaft by 20-30%! Can make for some odd characteristics... Like coasting and hitting your brakes on the highway.. You can feel the slop..
    Also, when the unit isn't meshed and you create wheel spin, it will create force on the cog teeth and it will eventually slip and mesh creating a pretty good clunk...lol
    All is good, this is how it works..
    Look into the Powertrax first, it is a bit more graceful and is still a locker... Just more pieces...
    Lockright will work fine though.. I racked up 100k on one truck a tleast with one in it.. I took it out before selling th truck and put it in another one..lol... Tolerances never changed..
  12. Nov 27, 2017 at 11:41 AM
    #72
    GreekPEguy
    GreekPEguy Well-Known Member
    California
    2002 Prerunner, 3.4 TRD OR
    Adding my $.02 to the topic as a 2wd owner with a locker. You don't really need it, I hit the same trails as was mentioned before and never had the need to engage the locker. (Only used it a few times just in case but didn't really need it.) In my opinion money will be better spent on buying recovery gear. Such as traction boards, tow ropes, and shovel. Get some good AT tires, (I have General grabbers at2's, they are fantastic) and your good to go. Save the money your would of spent on a locker on something else (lights, cb radios, ect.)
    dirtnsmores likes this.
  13. Nov 27, 2017 at 3:13 PM
    #73
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The E-lockers aren't "electronic". The "E" just stands for electric, which just refers to the type of actuator that engages the locker. The most common aftermarket are "air" (ARB lockers) where a compressed air solenoid engaged the locker. For our e-lockers, it is an electric solenoid. The "meat" behind the lockers themselves are more or less the same.
  14. Nov 27, 2017 at 4:36 PM
    #74
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Who makes the Lockright unit you're referring to ?
  15. Nov 27, 2017 at 4:55 PM
    #75
    Pot_Lickr
    Ontario, Canada
    Richmond gear..
    They make the Lock right
    And the Powertrax..
  16. Nov 27, 2017 at 5:00 PM
    #76
    Keep on Truckin'
    Jarvis
    Indiana
    Richmond Gear = Powertrax Lockright Locker also the Powertrax No-Slip ( LSD) Lunchbox units
  17. Nov 27, 2017 at 5:28 PM
    #77
    Pot_Lickr
    Ontario, Canada
    The " Powertrax no slip" is just a smoother operating version of the Lock Right... Its still a locker..
    I see Powertrax offers an LSD now though...
    A lot has changed since I was into these, it all used to be under Richmond Gear..lol
    And all they had was the Lock Right and No Slip..
